Best A/C adapter to use with YBox2 - 3.3V regulator question
Talk about YBoxen, widgets, Propeller hacking, etc!
Postby brianez21 » Tue Jun 08, 2010 6:51 pm
The YBox2 uses a TO-220 3.3V voltage regulator. I noticed that mine gets very hot after only a few minutes of being powered on. I was wondering if this is because I am using the 9VDC regulated power supply (purchased from adafruit) and if using a lower voltage regulated power supply (5VDC) will have any noticeable heat reduction. Also, I looked in the datasheet and could not find a minimum voltage requirement to operate the regulator, only a maximum. Does anyone know what this might be?
Thanks in advance for your help.
- Brian
brianez21
Re: Best A/C adapter to use with YBox2 - 3.3V regulator question
Postby adafruit » Fri Jun 11, 2010 9:34 am
the 9V adapter is a tiny bit high but it is within the temperature range of the package (we tested it)
that said, if you have a 5V adapter - that would probably be way better.
Postby brianez21 » Fri Jun 11, 2010 10:07 am
Okay, thanks for your input on this. The reason I was asking about the 5V adapter is because the silkscreen on the board says "6V" and I wanted to make sure 5V would not be too low.
You wouldn't happen to have a suggested place to buy a 5V or 6V DC power supply from?
- Brian
brianez21
Postby baobrien » Mon Jun 14, 2010 10:21 pm
Be careful with the supply, though. I did something stupid and used a 12v router supply. The regulator got hot (obviously) , so I put a coin on it to act as a bit of a heatsink. The coin slipped, crossed the Vin and Vout, and blew up my propeller! I had another one lying around, and all of the other components still seemed to work, but be careful!
I'm now using a 5v recycled cell phone charger.
If it's not broken, take it apart and fix it.
baobrien
Postby brianez21 » Tue Jun 15, 2010 6:48 am
From what I've read on the forums, the metal clip on the regulator in the ybox2 is connected to VDD and not ground, which makes it difficult to heatsink it to the case. I wonder if someone came up with a good heatsink idea for it. By the way, 12V is probably a bit too much.
- Brian
brianez21
Postby baobrien » Tue Jun 15, 2010 12:36 pm
I found that out :)
baobrien
Postby brianez21 » Tue Jun 15, 2010 7:42 pm
Oh, we all have at one point or another. It's always good to learn lessons on $10 components than to make mistakes on $100+ components :) I'm going to try the 5V adapter after I buy it (and wait for shipping, etc.), will probably report back here if anyone is interested but I fully expect it to work fine.
- Brian
brianez21
Postby bradk » Thu Sep 09, 2010 10:23 am
I use one of 6VDC @ 500mA Regulated Power Supply : MW41-650A. As there is a store close to me, I was able to easily pick one up.
It runs warm, but not hot-to-the-touch or OMG-keep-the-baby-away-from-it.
I really need to mount the thing into a box ...I just can't drill altoids boxes to save my soul ...
bradk
Postby brianez21 » Sun Sep 19, 2010 11:12 pm
Sorry it took so long for me to post back my results, but I just wanted to let you all know that a 5V/1A DC adapter from Polulu seems to be working great. The regulator stays completely cool to the touch!
- Brian
brianez21
Postby njbair » Sun Oct 17, 2010 6:20 am
I have one of those adjustable AC adapters with a whole set of plug tips. Works fine at 4.5V.
njbair
Return to YBox2
New Products [102]
LEDs[109]
Cables[60]
