where to buy midisense resistant board
Posts about MIDIsense. open source MIDI sensor platform
Postby mikele666 » Sat Jun 13, 2009 1:05 pm
mikele666
Re: where to buy midisense resistant board
Postby adafruit » Sat Sep 05, 2009 12:44 pm
sorry the project is being discontinued and we arent making any more. you can download the files and have PCBs made if you like :)
Postby ainsleyclark » Thu Jun 17, 2010 7:33 am
Who do I ask, to get the PCB Boards made?
Also how much will you sell them for?
Its a pitty this product has been discontinued....
Thanks very much.
ainsleyclark
Postby ainsleyclark » Thu Jun 17, 2010 7:57 am
Thanks for the quick reply...
What Im after is a board that can have up to 40 inputs for photocell sensors attached.
Im a bit of a newbie at this.
I have seen this http://www.doepfer.de/usb64.htm
Can I attach the light sensors to this??
Thanks for your help
ainsleyclark
Postby adafruit_support_bill » Thu Jun 17, 2010 8:09 am
That board has analog inputs that take 0-5v. That is the same range as the analog inputs on the arduino.
This tutorial shows how to connect a light sensor to an arduino. It should be applicable to that board as well: http://www.ladyada.net/learn/sensors/cds.html
Postby ainsleyclark » Thu Jun 17, 2010 8:22 am
Thanks very much for the reply.
Is threre a board you can recommend that doesent take to much programming and have a MIDI out connection?
Basically I want 40 Light sensors attached to the board, with lasers pointing towards the sensors.
Just like the laser harp: http://www.ladyada.net/make/midisense/laserharp.html but on a much bigger scale.
Thankyou.
ainsleyclark
Postby adafruit_support_bill » Thu Jun 17, 2010 8:33 am
MIDI is not my area of expertise. Maybe one of the other forum regulars will have some suggestions for you.
Postby ainsleyclark » Thu Jun 17, 2010 9:44 am
Thanks for the help anyway.
Ive seen this one, which looks pretty promising:
http://highlyliquid.com/midi-controllers/midi-cpu/
ainsleyclark
Postby textile » Mon Jun 21, 2010 1:50 am
I will have a version of MIDIsense boards available soon. Within a month or so. :D
textile
Postby isak » Sat Jul 31, 2010 8:37 am
Hi textile
from here http://adafruit.com/forums/viewtopic.php?f=14&t=12708 i can see that i can add a midi to cv/gate, can i use it with an SH101 to play in banned? i mean to write midi notes from the SH101 inside banned.
isak
Postby textile » Sun Aug 01, 2010 7:49 pm
It could be done with some fine adjustment. I will set up a test and see just how fine it can go.
Is the sh101 1v/oct or hz/volts?
textile
Postby textile » Sun Aug 01, 2010 7:55 pm
Oh yeah I will have this option on the boards that I will be selling. Resistive or Voltage to Midi. :wink:
textile
Postby isak » Mon Aug 02, 2010 2:08 am
so...? did u did it? did u tried it on SH101? :shock:
isak
Postby textile » Tue Aug 03, 2010 12:27 am
I don't have a sh101 :( But I will test for 1v/oct tracking (reverse)
I might get the time to do it later tonight. I have a few x0x orders to build quickly.
textile
Next
Return to MIDIsense
New Products [102]
LEDs[109]
Cables[60]
