New CPU Project
Re: New CPU Project
Postby textile » Mon Jun 21, 2010 2:04 am
:D
All connections are the same so the stock firmware should run with a simple modification to the chip definition file (hopefully). With what I know this will work.
textile
Re: New CPU Project
Postby dnigrin » Mon Jun 21, 2010 6:19 am
Definitely interested!
Dan Nigrin - Defective Records
CycliC, M185 & Klee Sequencers / MC-202 & MC-4 Hack / Jack OS X / Major Malfunction / PC-1600 User
http://www.defectiverecords.com
http://www.jackosx.com
dnigrin
Re: New CPU Project
Postby kroutshev » Mon Jun 21, 2010 9:40 am
Yep I'm interested too but is it x0xi0 full mode compatible ?
kroutshev
Re: New CPU Project
Postby wonkyfunk303 » Tue Jun 22, 2010 8:36 am
I will have one!! How much to post to uk? And when will it be available?
Oh also I gather I can just plug n play it!!
wonkyfunk303
Re: New CPU Project
Postby LZ303 » Tue Jun 22, 2010 10:51 am
Thanks for this project ...
Count me in :) Any idea about a final costs?
LZ303
Re: New CPU Project
Postby textile » Tue Jun 22, 2010 7:06 pm
The x0xi0 should work , its just hardware mods , yeah?
Plug in play yes.
It should be available late July. Cost around $50 built . Blank boards will be available as well.
work so far..... 23 june 2010
turbo cpu.png (19.51 KiB) Viewed 2184 times
textile
Re: New CPU Project
Postby darffader » Tue Jun 22, 2010 7:50 pm
looks good (and suits my avatar lol)
any chance you can make the solderpads for the thru hole components round?
this will make the overal print more reliable
as for the x0xI0, the cpu is on another place on the pcb, its on the side (near the switches)
Will it connect with a flatcable?
darffader
Re: New CPU Project
Postby textile » Tue Jun 22, 2010 8:06 pm
Yeah I am going to change the pads . I prefer round .
I have the i/o connectors like that as it was near impossible to trace with IDE. I will probably re-arrange them slightly for easier connection. These will be used for hacking so removable pins will be the best.
I am putting this directly on to a new board I am working on.
I will go and look at the x0xi0 site at his boards.
textile
Re: New CPU Project
Postby guest » Tue Jun 22, 2010 9:36 pm
is there a crystal mounted on the board
or are those long traces going to the mainboard crystal
if its on the mainboard
the crystal may not work so well
being that far away from the driver on the micro
guest
Re: New CPU Project
Postby antto » Tue Jun 22, 2010 11:10 pm
cooooool! :mrgreen:
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
antto
Re: New CPU Project
Postby bcbox » Wed Jun 23, 2010 1:31 pm
yes, it will work fine with the standard x0x pcb.
The custom mainboard is different though, much tighter, it's all the way on the side. With the current layout the adapter pcb would have to be located in a different spot and wire/cable used to connect to the existing footprint.
Regarding the crystal, definitely put it on the new board right next to the micro.
bcbox
Re: New CPU Project
Postby textile » Fri Jul 02, 2010 6:25 pm
II was going to ask about the crystal. Done.
The x0xi0 is a tight fit. A different board might be required .
textile
Re: New CPU Project
Postby darffader » Sat Jul 03, 2010 5:00 pm
if it doesnt fit with custom x0xI0 pcb, i'm afraid i'll have to opt-out till it does. :(
darffader
Re: New CPU Project
Postby textile » Sat Jul 03, 2010 11:47 pm
Ok. Who else needs it to fit with the x0xi0?
I will just have to do another board for this too. I have a little time before my next pcb run. I'll see how it goes :D
textile
Re: New CPU Project
Postby rarara » Sun Jul 04, 2010 3:23 am
do you mean the full xoxio upgrade from bcbox or just the distortion/io one? i have the latter and would be keen for the cpu upgrade
rarara
PreviousNext
Return to x0xm0dz
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
