Good distortion/overdrive circuits?
Postby Luap » Sat Jun 26, 2010 12:37 pm
Anyone got some experience with these? I would like to build one into one of my x0xb0xes, but am unsure which is the most suitable.
I have tried Julian Voirins wasp distortion mod, as it was the nicest sounding one in the demo's I heard. But it didn't really work out unfortunately. It sounded quite good, but not as nice as the demo's, plus even when switched out, it was interfering with the standard sound a little. After much messing around with the proto board, I gave up and ditched it.
What others come recommended around here?
And yes, I know there is a multitude of guitar pedals I could use. But i'd really like to build a nice overdrive circuit of some kind into my x0xb0x.
Thanks in advance :)
Luap
Re: Good distortion/overdrive circuits?
Postby Altitude » Sun Jun 27, 2010 6:09 am
I use a fulltone stomp box overdrive and it works wonderfully.
Altitude
Postby Luap » Sun Jun 27, 2010 5:43 pm
Altitude wrote:I use a fulltone stomp box overdrive and it works wonderfully.
Thanks Altitude. But that sounds like a pedal? Or did you build it into your x0x? Im open for hacking inexpensive pedals into it too, if do-able. But im definitely after a built in overdrive/distortion mod, rather than external.
Luap
Postby bcbox » Sun Jun 27, 2010 9:43 pm
The x0xi0 I/O kit has a distortion & overdrive built in.
I make my schematics available on the website. You could build one of my kits ($140) or make use of the schematics...
http://alphazone1.com/x0xi0/schematic/i ... atics.html
There's also the accenter-tool1 from the beepworld guy (germany). It's pretty good, pretty much a TS-808 with different values. It could fit inside the x0xb0x if you wired up panel-mounted pots and switches. I believe it's about $70US.
http://www.beepworld.de/members52/accen ... tool-1.htm
bcbox
Postby darffader » Mon Jun 28, 2010 7:03 am
Don't forget the ACID SCREAMER
It's a distortion/overdrive originally based on the infamous TS-808, but with lots of new features targeted specifically on the 303 sound. Stuff like dynamics restoration makes sure your accents dont get flatted out.
http://www.analoguerenaissance.com/TS303/
125 EUR excl shipping
assembled in my friends banned with the help of beautiful Flemish girls :mrgreen:
darffader
Postby Luap » Mon Jun 28, 2010 10:28 am
bcbox wrote:The x0xi0 I/O kit has a distortion & overdrive built in.
Aha, I toadally forgot that your x0xi0 mod has overdrive etc.. I may well go this way, so thanks for the reminder :)
darffader wrote:Don't forget the ACID SCREAMER
Don't forget, I specifically requested effects I could build in to the x0xb0x. No pedals/external boxes ;)
That said, it does look very nice. It even uses the very same knobs I used on my x0xb0x builds.
Luap
Postby Altitude » Mon Jun 28, 2010 10:46 am
Are you/they selling PCBs by any chance?
Altitude
Postby darffader » Tue Jun 29, 2010 12:25 am
Altitude wrote:Are you/they selling PCBs by any chance?
not me
and its smd,
quite complicated circuit, not recommendable as a diy thing
so no.
darffader
Postby darffader » Tue Jun 29, 2010 12:32 am
Luap wrote:Don't forget, I specifically requested effects I could build in to the x0xb0x. No pedals/external boxes ;)
i know.
but this is notable enough, i kinda prefer external effects.
some distortion mods pull down the power-supply (and affect the sound of the x0x), but as far as i see the x0xI0 handles this well
darffader
Postby textile » Sun Jul 04, 2010 12:01 am
With schematics for guitars you need to put in a 20k from the input then a 1k to the ground/0v. Since synths produce larger voltages. Otherwise the effect won't work. Check out Ken Stones 'Stomp Box Adaptor' page.
Tube screamers are good but I use a fuzz face with antique pnp transistors and a antique 6h1n tube overdrive. It dependes what sound you want . I use these with my cz101 and my jx'sv for a eerie macabre sounds. My evolver has distortion :D
Your better off increasing the output of the VCO and overdriving the VCF. Check out Wave Folders as well as these are very simple.
textile
Postby buddax » Wed Oct 06, 2010 12:52 pm
I did this very simple one, not build into the x0x, but i think it will be easy to fit. Power source can vary... think the opamp i use can handle up to 30V DC or whatever.
schematics, more or less =)
http://stuff.omgpwn.dk/x0x/clipper.png
Sound example
http://stuff.omgpwn.dk/x0x/diode_clipper01.mp3
http://stuff.omgpwn.dk/x0x/diode_clipper02.mp3
Sure there us room for improvement...
PS: ".tran 1" is ground, just an error on the drawing.
buddax
Postby Mussi81 » Mon Nov 15, 2010 4:47 pm
i know.
what about using an old stomp box that uses an 12v battery?
Mussi81
Postby IFadeToGrey » Tue Nov 16, 2010 12:55 am
textile wrote:Your better off increasing the output of the VCO and overdriving the VCF. Check out Wave Folders as well as these are very simple.
This is part of what gives the Minimoog gets it's signature sound.
IFadeToGrey
Return to x0xm0dz
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
