scsi wrote:mikeselectricstuff wrote:I'm just about to start looking into converting an old X-Y plotter into a paste dispenser for low-tech PCBs. I was thinking of just using a standard air dispensing system with controlled air times - I assume the auger head has a screw type element inside - do you have any info on the design of your head?
That's right, it's got a screw inside driven by a small stepper motor. Weights around 250g and has a very small footprint, smaller than a regular auger dispenser. I think a plotter should be able to handle it no problem. Shoot me an email if you want to beta test one.
Not sure my plotter would manage 250g! - I'd be interested to see the shape of the screw etc. and the general mechanical arrangement, e.g. how do you segregate the paste from the motor? A magnetic coupling might be nice if you could make it work.
Regarding auger type drives, I was thinking more along the lines of a small gearmotor to reduce size and weight compared to a stepper - maybe use the motor and box from an RC servo as a nice small light gearmotor, probably with an encoder for feedback.
I also wonder if there may be scope for something really crude - a simple (high-res) leadscrew into a syringe, like an infusion pump - this would eliminate the air volume issue. Maybe use a fairly small-bore syringe to reduce the 'gearing' between piston and paste movement. I also wonder if hydraulics may have advantages over pneumatics.
For the time-pressure dispensing, change in viscosity is an evil but not the biggest. The amount of air necessary to build up the pressure in the barrel varies as the syringe empties.
I wonder to what extent you could reduce this effect by upping the pressure and having precise timing (although the latter may get difficult). Or maybe have closed-loop control of pressure to effectively compensate for volume changes.
For what I need, I think pneumatic would work - I've done it by hand with a manually-timed foot- operated dispenser in the past - slightly under 1mm dot size would be OK - I don't mind hand-soldering the odd fine-pitch part.
As regards auger type dispensers, I wonder if you could use something as simple as a woodscrew as the drive element?
This was the very first thing I tried and it worked to some degree. Didn't last long though because the flux was attacking the screw...[/quote]
Stainless screws are readily available, and even if corrosion is a problem, if you could figure out a way to use an unmodified screw, you could just treat it as a consumable.A hex socket, torx or hexagon bolt head comes to mind,
or maybe something like this
