Mix in go through VCF?
Discuss mods, hacks, tweaks, etc.
Postby isak » Mon Jul 19, 2010 1:50 pm
can the mix in from i/o board can go through the VCF?
i have no room to the VCF audio in mod :?
isak
Re: Mix in go through VCF?
Postby Altitude » Mon Jul 19, 2010 2:06 pm
There is definitely a mod for that. try searching the mods forums
Altitude
Postby isak » Mon Jul 19, 2010 2:51 pm
yes there is, but not from the mix in, i said already.. i dont have a room left for a jack.
i want it to be from the mix in, is it possible?
isak
Postby Altitude » Mon Jul 19, 2010 3:08 pm
isak wrote:yes there is, but not from the mix in, i said already.. i dont have a room left for a jack.
Pin 3 of J7 is the "mix in" pin into the mixer on the mainboard connected to the socket on the I/O board, just disconnect it from the jumper on the mainboard are route it to the VCF
Altitude
Postby isak » Mon Jul 19, 2010 4:31 pm
i dont need to cut any trace somewhere?
just cut the jumper wire (pin 3) from the main board socket (not the i/o board) and take the wire that left connected on the i/o pin3 J7 and then connect it to the VCF?
where in the VCF?
thanks man :)
isak
Postby guest » Mon Jul 19, 2010 4:38 pm
youre going to need a capacitor and a resistor
solder a wire from ioboard j7 pin3 to a 47k resistor
you may want to experiment with resistor values
and the the other end of the resistor should go to a 10uF capacitor
this will be an electrolytic capacitor
so be sure that the resistor connects to the negative end of the capacitor
then solder the positive end of the capacitor
to the r70 and c17 juncture
whichever is easiest to get to is fine
guest
Postby isak » Mon Jul 19, 2010 4:42 pm
thanks again guest, u'r the man!
i'll be in the electric store tomorrow and buy the stuff and let u know.
isak
Postby isak » Tue Jul 20, 2010 2:11 am
guest,
r70 and c17 juncture is Q12 right leg or r62?
J7 pin3 still need to be connected to the main board or not?
isak
Postby guest » Tue Jul 20, 2010 3:26 am
its on the q12 side of c17
and j7 pin3 should no longer connect to the mainboard
although looking at the schematic more closely
you could just cut the trace between r156 and q34
and run a line from there to the vcf
and you wouldnt have to buy new parts if you didnt want to
although the values are a little off from what i would use
if you dont want to cut the trace
you could just lift the one leg of the resistor
and run the wire from that leg
guest
Postby isak » Tue Jul 20, 2010 4:31 am
i already buy the parts :? never mind its not that expensive.
ok, lift resistor r156 connect it to right leg Q12, like this?
isak
Postby guest » Tue Jul 20, 2010 12:37 pm
yes
that looks good
guest
Postby isak » Tue Jul 20, 2010 2:06 pm
thanks i'll update how it went :)
isak
Postby isak » Tue Jul 20, 2010 4:05 pm
i did it with a switch and it was not working :?
like this..
lift one side of r156, connect a wire from the pin resistor to the center of the switch.
in the empty hole of r156 i put a wire that goes to the left side of the switch.
from Q12 the right pin (the one that touches C17) i solder a wire and from there connect to the right side of the switch.
only when the switch is on the r156 (left side) its working.
when its from the right side (q12) not working.
did i did something wrong?
isak
Postby guest » Tue Jul 20, 2010 4:35 pm
measure the resistance
between the center switch pin
and the q12 side switch pin
and make sure the switch is connecting them
are you playing notes when you listen for sound
what signal level are you putting in
guest
Postby isak » Tue Jul 20, 2010 4:55 pm
when the switch is on the empty hole position (r156)its shows 121K
when its on the Q12 position its shows 00.4ohm
no.
i dont know, i plunged my x0x, mix out to mix in.
isak
Next
Return to x0xm0dz
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
