USBtiny on MacOSX
USBtiny on MacOSX
Postby uknative » Sun Jul 25, 2010 10:52 pm
After searching all over the interwebs I still cannot seem to get this to work.
I get this message from avrdude
Matts-MacBook:avrdude-5.9 matt$ avrdude -c usbtiny -p attiny2313 -U flash:w:test_leds.hex
avrdude: error: no usb support. Please compile again with libusb installed.
avrdude: programmer operation not supported
avrdude done. Thank you.
I have uninstalled avrdude and libusb.
then reinstalled (./configure, make, sudo make install) libusb
then
reinstall avrdude (./configure, make, sudo make install)
still getting this error message. Both install fine and bot are located in my home folder.
Any help would be greatly appreciated.
I know the Usbtiny works fine. because I can burn the arduino software onto a new '328 chip by plugging into the arduino board with the 6 pin cable and selecting burn bootloader in the menu.
any help would be greatly appreciated.
thanks in advance.
uknative
Re: USBtiny on MacOSX
Postby adafruit » Mon Jul 26, 2010 11:02 am
try grabbing avr mac pack?
Postby uknative » Mon Jul 26, 2010 4:10 pm
I did an uninstall on avrdude and installed avr mac pac.
I get the same error.
anybody have any ideas?
uknative
Postby adafruit » Mon Jul 26, 2010 8:51 pm
make sure you deleted your old avrdude, when you compiled it you didnt compile in USB support
Postby uknative » Tue Jul 27, 2010 9:32 am
Finally got cross packs to work.
After uninstalling and removing everything and
starting all over from scratch.
thanks for letting me rant on the forum.
uknative
Postby adafruit » Tue Jul 27, 2010 11:59 am
its tricky, but glad you got it cleaned up right. :mrgreen:
Postby smartrobot » Thu Aug 05, 2010 8:24 pm
When i plug USBtiny in it says a usb device is drawing to much power so one or more usb devices have been disabled how can i fix that
smartrobot
Postby adafruit » Thu Aug 05, 2010 9:35 pm
sounds like a short circuit or some part in backwards!
Postby smartrobot » Fri Aug 06, 2010 7:57 am
thaks I found the short
smartrobot
Return to USBtinyISP
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
