Ice clock socket direction
Tick Tock Clock Kits
Postby jkanzaki » Fri Sep 17, 2010 2:32 am
Hello
Iam new at electronic. When i solder in the socket on to the pcb board, i did not solder to the right direction. Does that matter? I know the chip must insert the right direction according to the silkscreen but does the socket has to install the right direction? cuz it's hard for me to remove all those pin.
Please help :)
thank you.
Any suggestion is appreciated.
jkanzaki
Re: Ice clock socket direction
Postby pstemari » Fri Sep 17, 2010 2:41 am
Which socket? The DIP socket isn't a problem--just insert the chip correctly. The square socket is a different story--you can only insert the chip one way.
--Paul
A wholly owned subsidiary of:
Persephone: DL R+W+B C 7 X L W C++ I++ T+ A E H++ S+ V-- F+ Q P B PA+ PL
Aldebaran: DM Rt H 5 Y L- W+ C+ I++ T++ A+++ E H++ S+ V+ F++ Q+ P B++ PA- PL--
pstemari
Return to Clocks
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
