Hi !
I was running my Arduino 328P based datalogger on the go-kart last weekend for the first time and I found it randomly resets itself when the engine is running and the higher the RPM the more it resets.
I suspected vibration to be the problem first, but after I have put as much paddng as I could, it would still happen.
Is it possible that the Electro magnetic pulse from the engine ignition (2-stroke so quite high frequency) causes the Arduino to reset itself? the board is in the plastic box at the moment and there are several sensor cables connected, that run along the engine RPM lead, which goes to another logger. ( I don't log RPM on Arduino yet).
Would I need some RC filters for each Analogue input?
Many thanks.
