XBee Midi Adapter
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
XBee Midi Adapter
Postby rschaef1 » Fri Aug 27, 2010 1:52 pm
Hi, first time posting here. I'm interested in building the Xbee wireless MIDI link, but don't actually want it to talk to a computer, simply between standard MIDI devices. This may sound like an obvious question, but could I just assemble another breadboarded Xbee Adapter with Midi jacks, buffer, and optocoupler and expect them to talk to each other? I like the simplicity of setting it up without an Arduino or other microcontroller, but just wanted to make sure that was possible. Thanks in advance!
rschaef1
Re: XBee Midi Adapter
Postby adafruit » Fri Aug 27, 2010 4:28 pm
should be fine BUT you still need a computer to talk to the xbees for configuration
Postby rschaef1 » Fri Aug 27, 2010 4:30 pm
great, thank you.
rschaef1
Postby chilimac » Thu Oct 21, 2010 5:22 pm
Any update regarding mac users with this amazing little project? Also will this send all midi data including sysex?
chilimac
Postby adafruit » Thu Oct 21, 2010 6:34 pm
we did not support a mac at the time (and still do not for that project) - if you figure it out please post up!
Postby chilimac » Mon Oct 25, 2010 7:22 pm
Sounds like a fun challenge. I haven't had a reason to dust off my much unused electronic engineering skills in decades. :)
Here is the first update.
This is the PDF from the ftdichip site regarding the set up of the modified drivers on a mac.
http://www.ftdichip.com/Support/Documents/TechnicalNotes/TN_105%20Adding%20Support%20for%20New%20FTDI%20Devices%20to%20Mac%20Driver.pdf
I am ordering the xbee boards and chips tonight so will post an update once I try the process on the mac side of my machine. I have a mac book pro with boot camp dual boot so I will be able to get the midi baud rate set up either way. My preference would be to have the whole set up work on mac so that I am sure I can have native support for my mac based music system software.
Here's to the next couple of days of baited breath while I wait for the ups guy (chick.)
chilimac
Postby chilimac » Mon Oct 25, 2010 7:26 pm
Oh one more thing.... ada...
you have a .png of the schematic on the tutorial. From what I have learned - I am guessing that you have an actual schematic file that you generated the .png from, or at one time did.
If this does work for me I want to punch out a couple of PCB's for the units and enclose them for some durability. You wouldn't happen to have the schematic files still lying around would you? (pretty please?) :)
chilimac
Postby chilimac » Mon Oct 25, 2010 7:44 pm
the actual drivers for mac may be found on the overall driver page...
http://www.ftdichip.com/FTDrivers.htm
chilimac
Postby adafruit » Mon Oct 25, 2010 9:17 pm
the schematic files were deleted
Postby chilimac » Sat Oct 30, 2010 1:21 pm
So I just finished putting together your xbee module board. Great instructions and great PCB. I was short 1 1k resister out of 2 packs. I will pick one up when I grab the rest of the materials for the midi adapters. One thing to note...
Perhaps its just me not reading things completely. I didn't realize the FTDI cable didn't come with the module kit. It seemed like it was a part of it. Perhaps you might want to clarify that it doesn't come with the kit.
Other then that I have one on order from you and am waiting for the cable and the remaining parts to put these babies together.
chilimac
Return to XBee products from Adafruit
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
