Alternate CODE02 Program
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
Postby scsosna » Wed Oct 27, 2010 7:37 pm
I enhanced the CODE02 program that came with the starter kit to do some other tricks, figured I'd share. Enjoy!
  How many LEDs are in the circuit.
const int PIN_COUNT = 8;
  Holds the digital pin numbers that the LEDs are hooked to.  If you add more LEDs to your
  circuit, make sure you add the correct pin numbers to the array.
const int ledPins[] = {2,3,4,5,6,7,8,9};
  Initialize the pins on the Arduino used for this circuit.
void setup()
  for (int i = 0; i < PIN_COUNT; i++)
    pinMode(ledPins[i], OUTPUT);
  Method called by Arduino to do its work.
void loop()
  ascend();
  descend();
  allOnOff();
  progression1();
  allOnOff();
  progression2();
  allOnOff();
  progression3();
  allOnOff();
  progression4();
  allOnOff();
  progression5();
  allOnOff();
  progression6();
  allOnOff();
  Flash each LED in ascending order.
void ascend()
    digitalWrite(ledPins[i], HIGH);
    delay(100);
    digitalWrite(ledPins[i], LOW);
  Flash each LED in descending order.
void descend()
  int descending[] = {9,8,7,6,5,4,3,2};
    digitalWrite(descending[i], HIGH);
    delay(100);
    digitalWrite(descending[i], LOW);
  Progression 1: In ascending order, turn on an LED and
  then turn on/off for all LEDs following it.  Finally,
  turn off the initial LED and move to the next one
  until all are exhausted.
  0,1,2,3,4,5,6,7
  1,2,3,4,5,6,7
  2,3,4,5,6,7
  etc
void progression1()
    for (int j = i + 1; j < PIN_COUNT; j++)
      digitalWrite(ledPins[j], HIGH);
      delay(100);
      digitalWrite(ledPins[j], LOW);
  Progression 2: In ascending order, turn on an LED and
  then swing up and back through the remaining lEDs, turning
  each on/off in order.  Finally, turn off the initial LED
  and move on to the next one until all are exhausted:
    0,1,2,3,4,5,6,7,6,5,4,3,2,1,0
    etc.
void progression2()
      delay(100);
    for (int j = PIN_COUNT - 1; j > i; j--)
      delay(100);
  Progression 3: In ascending order, turn on an LED and
  then turn on/off all remaining LEDs in order including
  the ones that proceed it:
    0,1,2,3,4,5,6,7
    1,2,3,4,5,6,7,0
    2,3,4,5,6,7,0,1
    etc.
void progression3()
    for (int j = i + 1; j < i + PIN_COUNT; j++)
      digitalWrite(ledPins[j% PIN_COUNT], HIGH);
      delay(100);
      digitalWrite(ledPins[j%PIN_COUNT], LOW);
  Progression 4: In ascending order, turn on an LED
  and then swing through all the remaining LEDs
  including the ones that precede the starting point:
    1,2,3,4,5,6,7,0,7,6,5,4,3,2,1
    2,3,4,5,6,7,0,1,0,7,6,5,4,3,2
    etc.
void progression4() {
  for (int i = 0; i < PIN_COUNT; i++) {
      digitalWrite(ledPins[j % PIN_COUNT], HIGH);
      delay(100);
      digitalWrite(ledPins[j % PIN_COUNT], LOW);
    for (int j = i + PIN_COUNT - 2; j > i; j--)
      delay(100);
  Progression 5: In ascending order, turn on an LED and then each
  following it without turning every one.  Once the loop is complete
  turn all LEDs off and move to the next LED in order and repeat
    0,1,2,3,4,5,6,7, all off
    etc.
void progression5() {
    for (int j = i; j < PIN_COUNT; j++)
      delay(100);
    delay(100);
    allOff();
  Progression 6: Swing back and forth through the LEDs
  moving inwards with each iteration, sort of like a
  swing losing its momentum
  1,2,3,4,5,6,5,4,3,2,1
  2,3,4,5,4,3,2
  3,4,3
void progression6() {
  for (int i = 0; i < PIN_COUNT/2; i++) {
    for (int j = i; j < PIN_COUNT-i; j++){
      delay(100 * (i + 1));
    for (int j = PIN_COUNT - 1 - i; j > i; j--) {
    allOff();
  Flash all the LEDs on/off once.
void allOnOff() {
    delay(200);
  Turn all the LEDs off.
void allOff() {
scsosna
Re: Alternate CODE02 Program
Postby adafruit_support_bill » Wed Oct 27, 2010 8:03 pm
Welcome to the forums and thanks for sharing! I took the liberty of editing your post. If you use the "Code" button when posting code, it preserves the formatting and makes it easier to read and copy to the clipboard.
Postby scottinnh » Sun Dec 26, 2010 8:55 pm
I just went through the exercise with the Starter Pack; Thanks for the alternate code..
FYI the (original) tutorials had some neat patterns, but completely overlooked the likely "most wanted", which is the Cylon (or Kitt) scanner aka Larson scanner.
Here's a Cylon function that drops right into the original CODE02:
* cylonScan() - Scan left to right to left to right..
void cylonScan(){
int delayTime = 100; //the time (in milliseconds) to pause between LEDs
//make smaller for quicker switching and larger for slower
for(int i = 0; i <= 7; i++){
int offLED = i - 1; //Calculate which LED was turned on last time through
if(i == 0) { //for i = 1 to 7 this is i minus 1 (i.e. if i = 2 we will
offLED = 7; //turn on LED 2 and off LED 1)
} //however if i = 0 we don't want to turn of led -1 (doesn't exist)
//instead we turn off LED 7, (looping around)
digitalWrite(ledPins[i], HIGH); //turn on LED #i
digitalWrite(ledPins[offLED], LOW); //turn off the LED we turned on last time
delay(delayTime);
for(int i = 7; i >= 0; i--){
int offLED = i + 1; //Calculate which LED was turned on last time through
if(i == 7) { //for i = 1 to 7 this is i minus 1 (i.e. if i = 2 we will
offLED = 0; //turn on LED 2 and off LED 1)
delay(delayTime);
scottinnh
Postby vdantes » Thu Mar 03, 2011 1:23 pm
Hello! I was hoping some kind soul might lend some assistance. I'm a sculptor and prop maker new to programming. I'm wrapping my brain around the concepts behind the structure and functions of coding, but am having a hard time figuring out how to manipulate the math variables to alter the code to create the animation I want. I've gotten the hang of changing the existing numbers to achieve different effects, but the animation would require writing new equations with different operators entirely, and it has me stumped.
The project I am working on is a steampunk Daft Punk helmet, with a MUCH simpler animation and much fewer LEDs than Guy Manuel's original. I've wired everything up, and I have two rows of four blue LEDs, one row on either side of the helmet. I want them all to light up starting at the bottom, and then all turn off starting at the bottom. I've fiddled around with the inAndOut code, so I have it set to light up and turn off one LED at a time, starting at the bottom and traveling up, then starting back down at the bottom again. But I can't figure out how to alter it in any way without breaking the code other than speeding it up or slowing it down.
Here's a gallery of photos of me in the costume. http://www.cosplay.com/gallery/197985/
Any help would be greatly appreciated!
Cheers,
Danny Ashby
CEO Outland Armour
http://www.OutlandArmour.com
vdantes
Postby vdantes » Sat Mar 05, 2011 10:19 pm
I don't have my sketch on this computer, so I just pulled the specific part I'm using from http://ardx.org/src/circ/CIRC02-code.txt.
* inAndOut() - This will turn on the two middle LEDs then the next two out
* making an in and out look
void inAndOut(){
  //runs the LEDs out from the middle
  for(int i = 0; i <= 3; i++){
      offLED = 3;        //turn on LED 2 and off LED 1)
    int onLED1 = 3 - i;       //this is the first LED to go on ie. LED #3 when i = 0 and LED
                             //#0 when i = 3
    int onLED2 = 4 + i;       //this is the first LED to go on ie. LED #4 when i = 0 and LED
                             //#7 when i = 3
    int offLED1 = 3 - offLED; //turns off the LED we turned on last time
    int offLED2 = 4 + offLED; //turns off the LED we turned on last time
    digitalWrite(ledPins[onLED1], HIGH);
    digitalWrite(ledPins[onLED2], HIGH);
    digitalWrite(ledPins[offLED1], LOW);
    digitalWrite(ledPins[offLED2], LOW);
    delay(delayTime);
vdantes
Postby adafruit_support_bill » Sun Mar 06, 2011 6:05 am
Assuming that everything is wired the same as in the example, you just need two 'for' loops. One to turn them on in order, and another to turn them off in the same order. Something like this:
* bottomUp() - THis will turn the lights on in sequence from the bottom up
* then turn them off in the same sequence
void bottomUp()
  //Turn on from the bottom up
                             //#0 when i = 3
                             //#7 when i = 3
    delay(delayTime);
  //Turn off from the bottom up
    int offLED1 = 3 - i;       //this is the first LED to go on ie. LED #3 when i = 0 and LED
                             //#0 when i = 3
    int offLED2 = 4 + i;       //this is the first LED to go on ie. LED #4 when i = 0 and LED
                             //#7 when i = 3
    delay(delayTime);
Postby enjo » Sun May 01, 2011 2:52 pm
To me, the inAndOut() code seemed overly complicated. It took me a few times reading through it to understand what they were doing. I made a more simplified version of the code that does the same thing:
void betterInAndOut(){
  int delayTime = 100;            //Time to wait between lights in ms.
  for(int i = 0; i <= 3; i++){          //Going in
    digitalWrite(ledPins[i], HIGH);     //Turn on low end
    digitalWrite(ledPins[7-i], HIGH);   //Turn on high end
    delay(delayTime);
    digitalWrite(ledPins[i], LOW);      //Turn off low end
    digitalWrite(ledPins[7-i], LOW);    //Turn off high end
  for(int i = 2; i >= 1; i--){          //Going out
    delay(delayTime);
Is there any reason why doing it the original way might be better?
enjo
Postby YasBean » Thu May 26, 2011 9:22 pm
I added two more LEDs, so I had 10. That required only changing PIN_COUNT and manually adding two more addresses when declaring ledPins[]. It worked, except for descend(). Here are some changes I made to descend():
const int PIN_COUNT = 10;
//LED Pin Variables
int ledPins[] = {2,3,4,5,6,7,8,9,10,11}; //An array to hold the pin each LED...
void descend()
//  int descending[] = {11,10,9,8,7,6,5,4,3,2};
  // this seemed unnecessary to me, since we already have ledPins[]
  for (int i = PIN_COUNT-1; i > 0; i--) //I use PIN_COUNT-1 so as to avoid the
                                                       //unsightly repeat lighting of the last LED
//    digitalWrite(descending[i], HIGH);
    delay(100);
//    digitalWrite(descending[i], LOW);
Simple changes, but it's all about refinement, right?
YasBean
Postby Felyrion » Tue Jul 05, 2011 6:03 pm
I just started playing around with this set myself, and i found another fun option to try.
It also introduces a small new (at this stage at least) function you can use for testing.
Here's my code (as it can be inserted in the original code):
void randomized(){
      int delayTime = 10;
      int randomLED = random(0,8);
      digitalWrite(ledPins[randomLED], HIGH);
      delay(delayTime);
      digitalWrite(ledPins[randomLED], LOW);
This randomly turns one of your LEDs on, waits the delay, and turns it off again.
With the delay set to around 10 it looks like the leds on a modem or switch :)
Felyrion
Postby phil_s_stein » Sun Jul 31, 2011 4:03 pm
I put all the different functions into one file and cleaned things up a bit.
This version iterates through the sequence using an array of function pointers. It also shows how to use sizeof to get the number of elements in an array without having to have an explicit variable to store it.
I also updated the randomized() function to do the random thing for a specific number of seconds (5).
http://pastebin.com/k0eXpX66
Note: this version uses pins 3-10 instead of 2-9 like the original one.
phil_s_stein
Postby zik » Tue Sep 27, 2011 2:30 am
Here's a version I did for a 5 LED circuit with a push button:
http://pastebin.com/VG7XLiNN
It uses bit fields to set and clear the LED states, so you can set up animations easily. It has 5 animations that you can switch between using the push button.
Adding your own animations should be very easy, each "frame" is 1 byte, each bit is the state of 1 of the LEDs (0 = off, 1 = on).
You should be able to use this with the stock CIRC02 circuit by using 8 bits instead of the 5 I use, and removing the button check.
To switch patterns, you would then have to change the index in the sketch and re-upload it.
zik
Postby tylertech » Mon Feb 27, 2012 4:37 pm
OP, here is the same code but I had it dynamically fill the array so if you add more LEDs it scales with you just changing the pin_count
//Int array for pin number
int ledPins[PIN_COUNT];
//Dynamically fills the array based on the PIN_COUNT Constant above
void fill_array(int ar[], int x)
    int y = 2;
    for(int i = 0; i < x; i++)
       ar[i] = y;
       y++;
void setup()
  fill_array(ledPins, PIN_COUNT);
void loop()
  ascend();
  descend();
  allOnOff();
  progression1();
  allOnOff();
  progression2();
  allOnOff();
  progression3();
  allOnOff();
  progression4();
  allOnOff();
  progression5();
  allOnOff();
  progression6();
  allOnOff();
void ascend()
    delay(100);
void descend()
    delay(100);
  0,1,2,3,4,5,6,7
  1,2,3,4,5,6,7
  2,3,4,5,6,7
  etc
void progression1()
      delay(100);
    etc.
void progression2()
      delay(100);
      delay(100);
    0,1,2,3,4,5,6,7
    1,2,3,4,5,6,7,0
    2,3,4,5,6,7,0,1
    etc.
void progression3()
      delay(100);
    etc.
      delay(100);
      delay(100);
    etc.
      delay(100);
    delay(100);
    allOff();
  2,3,4,5,4,3,2
  3,4,3
    allOff();
void allOnOff() {
    delay(200);
void allOff() {
tylertech
Return to Arduino Starter Pack
New Products [103]
LEDs[109]
Cables[61]
