Can't get 4, only banks - what to try?
SpokePOV kit for bikes
Postby shprung » Fri Oct 29, 2010 12:43 pm
out of the blue, I can no longer program the 4 banks - only 2. The software upon 'connect' (I am using USB) shows only 2 banks and not 4 for all my 3 POVs.
To be sure, I installed the software, ver1.4, on my 3 computers (w7, vista, XP) and it all result in the same thing so I suspect the USB or the POVs.
I recall in the past that one of the POV was showing only 2 banks but somehow it got fixed by itself on later attempt. Now, it all the time showing only 2 banks.
Yet, when it runs the animation, I do see the 4 banks/images
I usually first connect the USB to the computer and the POV - I get a single light, I then click on the POV button and get another light. In the software I then click connect... am I doing it different than you, should I try it differently?
shprung
Re: Can't get 4, only banks - what to try?
Postby adafruit » Mon Nov 01, 2010 10:53 am
try clearing out the two banks you have (load in empty BMP files)
Postby shprung » Thu Nov 04, 2010 1:41 am
didn't help. I 'write to SpokePOV' a one-red-dot only, for both bank 1 and bank 2. I verify and even read from spokePOV to make sure it got clear from the old image. but upon diconnect & connect I only get to see 2 banks. Next, I remove the cheap and upon connection it show no banks at all. I put it back, and again it only show 2 banks. what to try/test next?
shprung
Postby adafruit » Fri Nov 05, 2010 12:21 pm
not sure what happened. but dont remove the chip. try uploading some patterns to the banks, maybe the other two will show up afterwards?
Postby dreamer.redeemer » Thu Nov 11, 2010 12:30 am
I'm having this same problem now, on 2 of the 3 boards. I've also had issues with leds doing the opposite of what they're supposed to for just one degree, when near vertical.
dreamer.redeemer
Postby dreamer.redeemer » Mon Jan 24, 2011 9:34 pm
I can get the last 2 banks to appear by filling the first two, disconnecting, then reconnecting. I'm still having the problem with the vertical line, I'm guessing it's over/underflow of some sort. Is the latest source available somewhere?
dreamer.redeemer
Postby adafruit » Tue Jan 25, 2011 2:33 pm
everything is on the download page!
Postby jrfoell » Fri Feb 03, 2012 8:20 pm
I'm also having the same issue on only one of my 3 SpokePOVs: In SpokePOV Soft I can connect and tabs for banks 1 & 2 will show up, but 3 & 4 will not. I also have the vertical line on the unit in question. Did anyone find a repeatable solution?
jrfoell
Postby jrfoell » Fri Feb 03, 2012 10:54 pm
Ok, so I found some repeat-ability with my setup... If I write the original spokepov.dat and flower.dat files on banks 1 & 2, disconnect and connect again, I'll see banks 3 & 4. It has something to do with the 4 dat files I created, maybe something is overflowing? The files I used are attached, and for me to reproduce the Bank 1 & 2 bug, they must go in this order:
Bank 1: 612brew.dat
Bank 2: v.dat
Bank 3: wordpress.dat
Bank 4: batman.dat
When I write all those to the SpokePOV, disconnect/re-connect, I'll only see Bank 1 & 2. Also, when I read Bank 1 from SpokePOV I can see the vertical line is now part of image that was stored.
To very clearly see the vertical line issue, I loaded v.dat on all 4 banks, disconnected/re-connected an then read bank 1.
At one point I tried loading v.dat in bank 1, and blank dat files in the other 3 and to my surprise when I disconnected/re-connected only the tab for Bank 1 showed up! Loading biohazard.dat into bank 1, disconnecting and re-connecting got the others back.
I'm willing to help debug/qa this issue if it's repeatable on others' systems/hardware.
sample bank bug dat.zip
(3.17 KiB) Downloaded 109 times
jrfoell
Postby tony18183 » Sun Feb 19, 2012 4:13 am
2 bank left in my EEPROM
I am having this problem now after I write into bank 3.
At first, I tried to write biohazard image into bank 3 but fail. I guessed some issue with the bmp that i upload. THen, I read bank 1 and save the image into "bank 1.dat" file. I write this .dat file into bank 3. when the writting was done i disconnected and reconnected again for verification. To my surprise, it only pop up 2 bank. 3 and 4 gone.
help please
tony18183
Postby tony18183 » Sun Feb 19, 2012 9:03 am
i installed it back on my wheel. 4 bank images show up..hmmm
tony18183
Postby neonglass » Sat Jun 16, 2012 5:28 pm
I seem to be having the opposite problem. My software is showing 32 banks.
neonglass
Postby CycleCars » Tue Sep 11, 2012 11:10 am
I am having this exact problem. Was there a formal resolution to this? Do I need to replace the EPROMS? I haven't pulled them and I cannot get to the SPOKEPOV 1.4 source to see how it works.
I lost 2 of the 4 banks to the SPOKEPOV software. But they are still they running obsolete images. I am afraid to further load the remaining 2 banks with anything for fear it will eliminate what little I have working. I will try loading an older version of SPOKEPOV (1.3?) and see if that changes things. It sure seems like it it is in the SpokePOV code, not the firmware. But I did also see that mysterious stripe described right before the banks went kablooey.
Another piece of info; This happened on ALL 3 of my boards. One after the other. I really think this is the SpokePOV v 1.4 software causing this OR the firmware has a glitch during run-time in the code that handles the magnet event. I wish I could get the SPOKEPOV source. But it is not on the sourceforge site. The Windows zip file is empty on the site. That's yet another question. :-?
CycleCars
Return to SpokePOV
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
