IC8 inserted backwards and powered.
Postby safetyboy » Wed Nov 17, 2010 5:26 am
Would this chip have blown? I reversed it again and am getting all led's working and switches.
Or would it be best to replaced this chip.
safetyboy
Re: IC8 inserted backwards and powered.
Postby guest » Wed Nov 17, 2010 10:51 am
if its working
dont fix it
guest
Postby safetyboy » Wed Nov 17, 2010 12:16 pm
I'm not getting any sound out though!
safetyboy
Postby guest » Wed Nov 17, 2010 12:44 pm
ic8 has nothing to do with the sound
it just lights up leds
do any of the modes work
like random mode
did you do all the tests during the build
did everything work before reversing ic8
guest
Postby safetyboy » Wed Nov 17, 2010 4:43 pm
all modes seem to work, i can here it pulsing through the headphones. all LED work and buttons..
i have no Oscilloscope, just a multimeter
IC15B pin 4 seems to go from 0v and build to 300mv then restart, is this right.?
Also USB works fine, computer finds it and the x0xb0x software see,s it. Just cant get audio out.
replaced IC8 with new one too.
this is also working fine
also this
safetyboy
Postby guest » Wed Nov 17, 2010 5:46 pm
do you hear any signal on the volume pot
when the x0x is playing
guest
Postby safetyboy » Wed Nov 17, 2010 6:48 pm
Nothing on the far right pin of the VC that i can hear audibly!
safetyboy
Postby guest » Wed Nov 17, 2010 6:51 pm
did it ever make sound
its probably ic15
compare the voltages on it
to the ones shown in the troubleshooting section
guest
Postby guest » Wed Nov 17, 2010 6:57 pm
here are those voltages
i always forget where they are at
pin / dc bias / ac signal
1 / 5.3v / 10mv
2 / 5.3v / 0mv
3 / 0.0v / 0mv
4 / 0.0v / 1.2v
5 / 0.0v / 0v
6 / 5.3v / 750mv
7 / 5.3v / 750mv
8 / 5.3v / 750mv
9 / 12v / 0v
pin4 is the signal from the gate
so it should go to 1.2v when the gate is high
and 0v when the gate is low
the signal at pin1 is very hard to see except on a clean scope
guest
Postby safetyboy » Thu Nov 18, 2010 3:32 am
1 - 5.35
2 - 5.3
3 - 0.1mV
4 - 10V
5 - 0.0V
6 - 5.3
7 - 5.3
8 - 8.3mV
9 - 11.9
The Batch number is 743 H32
safetyboy
Postby guest » Thu Nov 18, 2010 10:10 am
is the part number ba6110
and do you have it in the ic15b placement
and is it orientated properly
pin4 being at 10v is really bad
although earlier you stated it was only 300mv
check for shorts to ground around pin8
guest
Postby safetyboy » Thu Nov 18, 2010 10:23 am
Its BA6110, IC15B and Orientated right!
10V on pin 4, would this be a bad chip or a short? all Cap's are orientated OK and the right values.
Pin 5 is grounded thats all
safetyboy
Postby guest » Thu Nov 18, 2010 1:28 pm
rehit the solder joints on ic15
and then double check q1 through q4
for proper part and orientation
if it still is 10v on pin4 after that
then ic15 is bad
guest
Postby safetyboy » Thu Nov 18, 2010 2:17 pm
OK so i started with just the power jumper in and pin 4 on BA6110 is @ 300mv and is like that until i plug in the last jumper which is J3 at the micro controller
Then it jumps up to 7-11V
Thanks so much for the help by the way, i would be pulling my hair out without it :D
safetyboy
Postby guest » Thu Nov 18, 2010 3:30 pm
that sounds like a bad ba6110
you might want to check the current coming out of q1
before you put a new ba6110 in
just to make sure that it wasnt damaged by something else
guest
Next
Return to Making x0x
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
