by antto » Sun Oct 03, 2010 11:44 am
n0nx0x is useful only if you really like the original 303 interface
or if you're familiar with a similar sequencer (i don't know if there are others)
on a real 303, you have 2 "modes" for a pattern, 16ths and triplets
16ths means - each beat is sliced into 8, each odd numbered segment is a note
triplets: each beat is sliced into 6, each odd numbered segment is a note
the note length itself is programmed in TIME MODE
you can "extend" the notes (to make em longer) in two ways
and the notes themselves are sepparated from the TIME information, they can be edited in PITCH MODE
the pattern length tells how much (time mode) steps the pattern has but depending on the triplet mode:
triplet mode ON - 12 steps are 4 beats
triplet mode OFF - 16 steps are 4 beats
also, to use this OS you really need to put an overlay, because i've changed the button labels
you can cut an overlay from a sheet of paper (like i did)
here's a quote from the documentation: (beta 1.02)
Pattern Length menu
You can only access the Pattern Length menu from the Main menu - EDIT.
1. Hold FUNCTION
The bank leds (1 to 16) indicate the current pattern length.
Releasing the FUNCTION button leaves you back to the Main menu, saving any changes you made.
While in the Pattern Length menu, you can modify the pattern length or set Tripplets mode for that pattern.
2. To modify the length - press "STEP" and watch the LED indication, when ready - release the FUNCTION button.
If the new length of the pattern is less than 16, the remaining steps in the TimeData are erased and set to "Rest"
3. To set Tripplets mode - press the "Tripplet" button. Even that you're still holding the FUNCTION button, you
will be returned back to the Main menu. Pattern Length is automaticaly set to 12 (equivalent to 16 steps normal pattern).
You can still change the Pattern length, but the possible range now is 1 to 15. Setting the length to 16
deactivates Tripplets mode for that pattern.
Time Mode menu
You can access it from the Main menu - EDIT.
Press the "TIME MODE" button - the "TIME MODE" LED lights up.
To escape this menu - press "FUNCTION", it returns you back to the Main menu.
In the TimeMode menu you can write the TimeData for the pattern or view the existing.
To view the existing TimeData - press "NEXT".
The bank leds (1 to 16) indicate the current position in the pattern, and one of the
Gate/Tie/Rest LEDs will light up showing the Time value for this step.
You will automaticaly escape this menu once you advance over the end of the pattern.
To write the TimeData - simply press one of the Gate/Tie/Rest buttons and watch the
pattern position indication (1 to 16). Setting a value (G/O/-) automaticaly advances to the next step.
Pitch Mode menu
Press the "PITCH MODE" button - the "PITCH MODE" LED lights up.
NoteData is simply a list of 16 notes.
Each note consists of the following values:
- Key ................... c to upper C
- Transpose(UD) ..... in octaves - Up, Down, or Up+Down
- Accent ............... on/off
- Slide .................. on/off
For short, we will refer to the Transpose/Accent/Slide value with the abbreviation "UDAS".
In the PitchMode menu, you can write new Notes, or assign UDAS to the existing notes.
The bank LEDs (1 to 16) indicate the position in the list. This has nothing to do with TimeData.
To write notes - press the desired keys on the keyboard. n0nx0x will play the notes.
By pressing a note, you overwrite the existing note in the list, and the UDAS information is set to 0.
Watch the position indication, as you will be auto-advancing.
To view the existing NoteData - hold "NEXT", you will hear the Note play, the "UDAS" information
will be shown with the UP/DOWN/ACCENT/SLIDE LEDs and the Key will be shown on the keyboard LEDs.
While still holding the "NEXT" button - you can modify the Note (Key/UDAS) information.
By default, the transpose values (UD) are set to 0. The Note key is then set to 2nd octave.
For example, a d# becomes d#2, c becomes c-2, and C becomes C-3 (upper C on the keyboard).
Up transposes the keys to octave 3.
Down transposes the keys to octave 1.
Up+Down is an extra, it transposes the keys to octave 4.
Pattern Editing is permanent, everything you do here (unless stated otherwise) is directly written to
the pattern memory.
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
