XBee Pro Series 2
Xbee projects like the adapter, xbee tutorials, tweetawatt/wattcher, etc. purchased at Adafruit
XBee Pro Series 2
Postby gigawhiteshadow » Tue Nov 30, 2010 9:49 am
i have a problem with my XBee Shields (Hardware XBee Pro Series 2 60mW). I would like to reduce the transmitpower (ATPL) to 0. Default Value is 4. I am configuring my XBee Shields with the X-CTU Software. Function Set ist ZNet 2.5 Coordinator AT. I can not change the value in th PL field. It say that XBee Pro supports a fixed transmit Power. I have no clue what to do. I also tried to configure the Xbee Shield with the terminal:
+++ OK
ATPL
4
ATPL0
ERROR
ATPL 0
ERROR
Is that a common Problem, or what am i doing wrong?
Thanks for you help
gigawhiteshadow
Re: XBee Pro Series 2
Postby adafruit_support_bill » Tue Nov 30, 2010 9:57 am
It looks like the shield is working OK. The problem is with configuring the XBee. Adafruit doesn't carry the Series-2 modules. Have you tried the Digi support forums?
Postby gigawhiteshadow » Tue Nov 30, 2010 10:02 am
Nope i didn't, i will do that, but you have no clue what the problem could be?
gigawhiteshadow
Postby adafruit_support_bill » Tue Nov 30, 2010 10:22 am
Sorry, no. I've never worked with those modules or ATPL.
Postby gigawhiteshadow » Tue Nov 30, 2010 10:38 am
Ok, thanks anyway. I have posted in the forum you told me, hopefully they know what i can do. That problem is quite wired, because i can configure the shield normally. Only this value isn't configurable. If I get it fixed i will post it.
gigawhiteshadow
Postby adafruit » Tue Nov 30, 2010 12:25 pm
hi there, we dont sell or support the xbee shield or series 2 xbees. we suggest contacting the place you purchased these from for more support. thanks!
Postby chillintau » Tue Feb 01, 2011 10:18 am
If you look at the command table, the Xbee Pros only have one option for the PL command, and that is '4.' You could try to use the PM command to turn off boost mode, but that will not change the output power of the radio.
chillintau
Postby dg12 » Thu Feb 03, 2011 4:00 pm
WHy do you want to reduce the output power to 0.?
dg12
Return to XBee products from Adafruit
New Products [102]
LEDs[109]
Cables[60]
