New 303-style Aluminum Enclosures
Re: New 303-style Aluminum Enclosures
Postby phono » Thu Dec 09, 2010 2:11 pm
the leds in this case are just down to how it was built, i think its probably due to the fact that there wernt any led standoffs used in the build, so chances are they were soldered with the face plate on (so they drop down a lot but all at the same level).
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
Postby Computer Controlled » Sun Dec 12, 2010 4:26 am
I wonder if i'm gonna have to re-seat my flat LEDs whenever i get one of these.
Synths: SH-1 . SH-101 . TB-303 . JX-3P . x0xb0x . uWave II . Alesis Ion . Pro-One w/Synthwood case . MoPho . Monotron
Drum Machines: TR-707 . R-70 . E-MU Procussion
Computer Controlled
Postby SubStyler » Sun Dec 12, 2010 7:13 am
if your flat LEDs fit in the standard case it will also fit in the aluminum case I think.
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
SubStyler
Postby Computer Controlled » Sun Dec 12, 2010 3:27 pm
Right now, they are level with the surface.
Computer Controlled
Postby SubStyler » Sun Dec 12, 2010 3:53 pm
okay... the welded screw mounts on my frontplates are 11.95mm long, if I'm not wrong the 15/32" mounts are 11.91mm long? the frontplates are made from 1.5mm aluminum.
so imho it should fit, but I've not tested this yet.
SubStyler
Postby Computer Controlled » Sun Dec 12, 2010 3:58 pm
Guess i'll find out at some point =o]
Computer Controlled
Postby kapitein ortega » Wed Dec 15, 2010 9:27 am
Hi guys, hope this is not a stupid question, but if I wanna change front plates, can you simply pull of the filter knobs? I'm pulling but they won't let go.. Got this one: Image
kapitein ortega
Postby guest » Wed Dec 15, 2010 4:31 pm
if you dont see any screw holes
then they should just pull off
if you can slip a small screwdriver under them
you can pry them off
but be sure to apply force evenly
guest
Postby kapitein ortega » Thu Dec 16, 2010 4:49 am
guest wrote:if you dont see any screw holes
Thanks, will give this a shot tonight :)
kapitein ortega
Postby charlie_says » Thu Dec 16, 2010 7:40 am
re. Removing knobs.
A method I was told (and have subsequently used successfully) is to loop a piece of wire under the knob and pull up. This means you should apply force evenly, and shouldn't move the pot in a way that will damage it or the board, or loosen the solder points.
Once I got them off, I put some silicon grease on the shafts to ensure I didn't repeat the problem at a later date.
charlie_says
Postby phono » Fri Dec 17, 2010 1:39 am
One trick to get off stuck knobs is to use a small spoon as a lever
phono
Willzyx x0xb0x Fitting Problems
Postby rvanscotter » Tue Dec 21, 2010 10:30 pm
Willzyx x0xb0x Fitting Issues
I/O Board mods went well, no apparent problems at this time.
The fitting of the panel to the PCB, went surprisingly well, with no problems at all. All I had to do was rotate the REST ACCENT and SLIDE caps. The side pieces attached easily, the problems are with C41 C36 J6 and most notably J3. With respect to C36 and C41, they need to be moved away from each other and the heat sink from IC20 must be removed. Not sure how that will affect things, IC20 will be right above C36 C41 Q32...
WIllzyx kits come with quick connectors for J3, J4, J5, J6, J7 on the PCB. J4, J5, J7 are not affected but there is no way to slide the PCB into position with those quick connectors. As a solution, I will have to cut the female quick connector off of the wires and solder in a replacement single female pins. The the male side of the quick connector on the I/O board will need to be bent outward to make it all fit.
Prognosis? It will work, but you will spend a few hours and need some patients and soldering skills to get it all done. Be CAREFUL not to mixup any of the IC J3 wires or you F^*k things up a bit.
I will post some pics when its done.
rvanscotter
Re: Willzyx x0xb0x Fitting Problems
Postby rarara » Wed Dec 22, 2010 2:12 am
rvanscotter wrote:Willzyx x0xb0x Fitting Issues
what are the i/o board mods you are referring to? is this part of the willzyz build?
rarara
Postby rvanscotter » Wed Dec 22, 2010 1:18 pm
The mods to the I/O board are the soldering in the wires for the new on/off switch and cutting the trace. The Willzyx kits come with quick connectors that you solder to the PCB and I/O board to be used with all the jumpers. being able to separate the PCB and I/O board is nice if you need to get into the kit. Because the AL enclosure is fairly thin there isn't enough room between the boards for them to fit together with the added thickness of the quick connectors.
rvanscotter
Postby rvanscotter » Thu Dec 23, 2010 12:28 am
I was able to complete the mods to my Willzyx x0xb0x so I could get it in the SubStyler AL enclosure. It works great. I will post some pics of the changes tomorrow but you can check it out on youtube at the link below!
Slayer - "Reign in Blood"
http://www.youtube.com/watch?v=crD449Q_Kig
rvanscotter
PreviousNext
Return to Making x0x
Users browsing this forum: mibignistinly and 3 guests
New Products [102]
LEDs[108]
Cables[60]
Prototyping[69]
