Atmega32u4 breakout board, typo on product description?
Postby auzieman » Tue Dec 21, 2010 2:38 pm
Correct me if I am wrong but the Atmega32u4 breakout board can use the USB connector for power right?
Also, and again pardon my ignorance but we can't use the IDE directly with this board? I saw a posting that sounded like you could but you had to compile then copy the hex file from the temp space and use averdude to send it to the board? Ideally I would like to just use the IDE from the arduino project. (but will use alternate if need be.)
Thanks in advance,
Auzieman
auzieman
Re: Atmega32u4 breakout board, typo on product description?
Postby adafruit » Tue Dec 21, 2010 2:59 pm
you can use the arduino IDE if you install teensyduino. we're using v19 and it works fine. follow our tutorial
it is powered over USB
Postby auzieman » Tue Dec 21, 2010 3:49 pm
Thanks much,
Now if only I could buy some of those cheap Chinese servos through you I'd have my shopping all done :) Once I get it all up and running I'll blog about it on my blogspot profile.
auzieman
Postby adafruit » Tue Dec 21, 2010 4:04 pm
we have servos in the robotics category, they are fairly inexpensive and we make sure the quality is good
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
