Suddenly no tone, just clicks. Please Help !
Re: Suddenly no tone, just clicks. Please Help !
Postby snazz » Sun Jan 02, 2011 7:03 pm
Hi again,
the BA6110 IC is located in slot IC15B and is oriented with the notch toward the back of the board where the I/O jacks are...
snazz
Postby guest » Sun Jan 02, 2011 7:23 pm
its looking like a bad ba6110
you can try setting it in keyboard mode
and then clipping a 220k resistor
from 12v to pin4 of the ba6110
this will bypass the envelope generator
the only other thing it can be besides for the ba6110
is the envelope generator putting too much current in
when the envelope is triggered
guest
Postby guest » Sun Jan 02, 2011 7:24 pm
also recheck all the ba6110 voltages
in keyboard mode without any key presses
and see if the same spikey voltages exist
guest
Postby snazz » Sun Jan 02, 2011 8:01 pm
in keyboard mode no keys pressed...
pins...going from the back end nearest the I/O's ... where the notch is...leading me to believe I'm starting at pin 1 ?
1. my scope says 5.5v ( but it might be slightly off it's pretty old me thinks )
2. my scope says 5.5v ( but it might be slightly off it's pretty old me thinks )
3. nuttin
4. nuttin
5. nuttin
6. scope says 5.25v
7. scope says 5.25v
8. 5.5v
9. 12v
holding the probe on pin 1, every time I hit a key, no matter which key...it dropped from 5.5v to 2.6v
I didn't do the 220k resistor thing...is that still relevant ?
snazz
Postby guest » Sun Jan 02, 2011 8:25 pm
all those voltages look ok
so its something that happens on the envelope
so try the 220k resistor thing
guest
Postby snazz » Sun Jan 02, 2011 8:36 pm
do you mean jump a 220k resistor from the pin with 12v on it pin 9 ? to pin 4 directly ?
snazz
Postby guest » Sun Jan 02, 2011 8:40 pm
yes
put one side of the resistor to pin9
and the other side to pin4
guest
Postby snazz » Sun Jan 02, 2011 8:47 pm
closest thing I have in the house is 100k ohm resistors right now...
i have 220 ohm
and 22K ohm
and the 100k ohm..
do I have to go buy a resistor ?
snazz
Postby guest » Sun Jan 02, 2011 9:01 pm
use the 100k resistor
guest
Postby snazz » Sun Jan 02, 2011 9:01 pm
found one ! hold on
snazz
Postby snazz » Sun Jan 02, 2011 9:19 pm
ok, so I made that jump, and the result in my head phones was...volume at max
What is different now s that the "clicking" and the notes are at a similar yet very very low volume, a similar volume to where the osc has been riding.
I have the volume turned all the way up on the x0x...this is where I was hearing the notes/osc in the distant background before, and the "clicking" way way in the foreground ( like ouch in headphones )...now the "clicking" has been pushed back to where the osc is hangin' way way in the background
snazz
Postby guest » Sun Jan 02, 2011 9:46 pm
if you have it in keyboard mode
with no keys pressed
and the 100k resistor in place
and you do not hear a tone
then the ba6110 is bad
or maybe not soldered in well
guest
Postby Altitude » Sun Jan 02, 2011 9:47 pm
this really sounds like a daff 6110 IMHO. I had one bad one that did almost the exact same thing
Altitude
Postby snazz » Sun Jan 02, 2011 10:22 pm
well,
I found a 220k resistor, and I had put that in, and upon further review..
I hear a tone...it is at an extremely low volume, the same volume as the tone has been...and when I hit keys I hear it play the notes as it should, just at that extremely low volume still...
so, with this resistor in-line...it's kinda working at a really really low volume...really low...
snazz
Postby guest » Sun Jan 02, 2011 10:27 pm
with the resistor in place
and no buttons pressed
check the voltage at pin8 of the ba6110
if the signal isnt a few volts
then chip is dead
guest
PreviousNext
Return to Making x0x
Users browsing this forum: Google [Bot] and 2 guests
New Products [103]
LEDs[109]
Cables[61]
