Decay not working! (solved)
Postby safetyboy » Wed Dec 22, 2010 3:53 pm
looked around for shorts but cant seem to find any!!
safetyboy
Re: Decay not working!
Postby mome rath » Wed Dec 22, 2010 4:32 pm
is the pot good?
mome rath
Postby Altitude » Wed Dec 22, 2010 8:54 pm
Altitude
Postby guest » Thu Dec 23, 2010 2:42 am
is the decay stuck short or long
does the accent work fine
guest
Postby safetyboy » Thu Dec 23, 2010 4:37 am
Accent works fine, as does everything else. I will do some testing later when i get home.
safetyboy
Postby aminoacid » Thu Dec 23, 2010 9:59 am
see that you havnt mixed the res pot and the decay pot together!
my machines kills fascists!
aminoacid
Postby safetyboy » Wed Jan 05, 2011 6:13 pm
aminoacid wrote:see that you havnt mixed the res pot and the decay pot together!
Whats the handiest pins to measure the resistance of the decay pot?
safetyboy
Postby guest » Wed Jan 05, 2011 7:01 pm
there are only three pins which are not connected to ground
measure the resistance across the outer two of these
guest
Postby Brassteacher » Wed Jan 05, 2011 8:40 pm
mome rath wrote:is the pot good?
Well, if it isn't, I certainly won't be able to help this time, agriculture and botany are not things in which I am well-versed.
Don Taylor, a.k.a. Brassteacher
"Jack of all trades, master of none, proficient at even fewer..."
Brassteacher
Postby safetyboy » Thu Jan 06, 2011 6:40 pm
Looking like the Res and Dec pots are mixed up! Ouch!
safetyboy
Postby Brassteacher » Thu Jan 06, 2011 9:21 pm
safetyboy wrote:Looking like the Res and Dec pots are mixed up! Ouch!
Just take your time removing them, don't get in a hurry or you may pull up traces from the board. Other than that, it's no big deal.
Brassteacher
Postby Altitude » Thu Jan 06, 2011 10:00 pm
I've done this a few times and I just pry up a corner a little at a time while heating the nearest pin
Altitude
Postby safetyboy » Sat Jan 08, 2011 3:00 pm
Swapped and fixed and sounding \o/ !!! cheers all!
safetyboy
Return to Making x0x
New Products [103]
LEDs[109]
Cables[61]
