headphone out problem
Postby sfr » Sat Jan 08, 2011 2:00 pm
hey folks,
Ive completed my XoXboX and the only problem so far is that my headphone out is ony just audible. I thought to ask here for any hints or tips to help solve the issue?
thanks
sfr
sfr
Re: headphone out problem
Postby guest » Sat Jan 08, 2011 11:39 pm
if you have a mixer
plug the mixout into it
and see if the sound level is good
then check that you have a solid 6v
on pin7 of ic14
guest
Postby stur » Sat May 07, 2011 1:47 pm
You can tell this is a hobby I've little time for!
Mix out is fine to the ear
Ic14 = 5.5v
stur
Postby guest » Sat May 07, 2011 5:36 pm
what are the voltages on all pins of ic14
listen with a pair of headphones
on all pins of j5
guest
Postby sfr » Sun May 08, 2011 6:36 am
hi ,
just ignore that last reading on pin 7 as i hadnt grounded properly!
i have a pair of headphones, do i wrap wire around the sleeve and ground it - then simply probe each pin?
these are the reading from each pin
1= 0.84
2= 1.89
3= 1.92
4= 2.53
5= 0.00 - :|
6= 1.38
7= 6.04
8= 0.82
9= 0.16
thanks
sfr
Postby guest » Sun May 08, 2011 6:59 am
connect an alligator clip or wire to the sleeve
and then touch the tip to pin1 of j5
if you dont hear anything
try pin6 of ic14
you should hear a quick pop sound
then listen on pin2
guest
Postby guest » Sun May 08, 2011 7:02 am
turn the power off
and measure the resistance to ground
from each pin of ic14
its looking like a bad chip
guest
Postby stur » Thu May 19, 2011 1:03 pm
Thanks very much for your time and assistance guest.
It was indeed a bad chip, trying to operate the wrong way round!
Must have been one that I did in the early hours with a few beers in me.
Cheers
stur
Postby guest » Fri May 20, 2011 1:16 am
did flipping it the right way around
fix the problem
glad to hear you found the cause
guest
Postby stur » Fri May 20, 2011 2:29 am
Yep!
stur
Return to Making x0x
New Products [103]
LEDs[109]
Cables[61]
