These Ni-Mh are just temporary and my main batteries will be a li-ion with 1.5V
However... this doesn't explain the weird behavior of my mintyboost.
As my life and my well-being depends on this phone and its mintyboost companion
I have no doubt that I will be able to make mine work OK... it's just a matter of time and of understanding what is wrong.
Oby One wrote:I will test tonight ,after my phone is empty again, in this way:
I will disconnect the battery pack from the mintyboost and connect instead the USB Li-Po Charger.
(that charger works ok ....and I have tested it already)
So I will provide a steady constant 4.2 V to minty boost.
If my mintyboost is constructed ok and it has no problem with its circuitry then it will charge my htc desire battery without a problem.
arduwino wrote:Hang on there. Just because the input is a steady 4.2 volts does not make it a good power source for the MintyBoost. The charger puts out a limited current (200mA I think) and the MintyBoost can't put out any more than what comes in.
arduwino wrote:You need to test with a real battery, and you need to be looking at the interface between MintyBoost and Phone.
What is the voltage output of the MintyBoost (while attached to the phone)
arduwino wrote:How much current is the phone pulling from the MintyBoost?
Without batteries?It should be good because it was used before with mintyboost by other users..
I think the next stage will be to try to power the mintyboost with the 4x NI-Mh battery pack but not using the diodes.
