How are you matching the transistors for the mirror?
antto wrote:uhm, wait
i'm not sure what you're talking about, i needed pictures of the square wave on oscilloscope
..at different notes
no one helped, so i recorded the VCO directly into my soundcard, and later - i "restored" the DC signals in the recording, not perfectly, but it works
i have a few new ideas but electronics are involved and i can't do it on my own, so i guess i can post it in the forum if someone likes to make em happen
one of them is about a PC oscilloscope
yes, there are already lots of apps, but so far - all of them don't handle the AC-coupling of the soundcard (and it looks like 90% of the soundcards are ac-coupled)
this means - with a soundcard scope - you can't see very low frequencies correctly (like 1Hz) because of the effect of the DC-Filter in the soundcard which is usually set to 1Hz to 20Hz (mine was 16Hz)
but there is a way to "restore" the DC content of the recorded signal afterwards
i wonder why no one made such an app that does this..
well, i guess this is not the place
here's what i did
i regret that i didn't take even lower freqs in the recording
i no longer have the same soundcard (the motherboard burned) and my current soundcard sux, it's pointless to record at 192K with it..
I'm 100% confident that all 303's used 1583F & 2291F. I've worked on dozens, never seen anything else. For the exponential converter, Q26, F/G/H doesn't make a difference, other than offsetting Ic slightly which will change the pitch of the VCO a few cents. Q21 of the differential amp is the most sensitive; there's not much difference with 1583G but 1583H makes a small audible difference. Q12 in the filter ladder doesn't sound any different regardless of which part is used. I do have samples of all these tests etc in my files, I just don't have the time to share it all at this point. It would be good to do these same type of tests to compare results.If any F, G or H rated transistors made it into any of the production TB-303s
bcbox wrote:I'm 100% confident that all 303's used 1583F & 2291F. I've worked on dozens, never seen anything else. For the exponential converter, Q26, F/G/H doesn't make a difference, other than offsetting Ic slightly which will change the pitch of the VCO a few cents. Q21 of the differential amp is the most sensitive; there's not much difference with 1583G but 1583H makes a small audible difference. Q12 in the filter ladder doesn't sound any different regardless of which part is used. I do have samples of all these tests etc in my files, I just don't have the time to share it all at this point. It would be good to do these same type of tests to compare results.If any F, G or H rated transistors made it into any of the production TB-303s
