As I'm trying to troubleshoot my 2nd x0x i thought i would map out the voltages on my other working x0x as a reference. I've done this as a new layer in the Freeware Eagle Layout 5.6 software over the ladyada Eagle mainboard layout.
Here's the modified file to load into Eagle layout
As I'm a total novice myself someone may want to go over this file to OK it but hopefully its fairly accurate. I set every working x0x dial to 0 except for Cutoff which was at about the 2o'clock position.
If you spot any glaring errors please pm me or post here.
I've noticed depending if you hit keyboard buttons when testing voltages this can alter volts drastically in the vco IC's and therefore other parts of the VCO. I believe I had my x0x in keyboard and pressed C to get 2.0V
