Programming - Can't find file/COM1
MiniPOV, MiniPOV2 and MiniPOV3
Postby Manicotti » Fri Nov 12, 2010 9:28 pm
Greetings - I'm trying to program the MiniPov3 on Win7 (built from a kit), and trying to program it using a USB serial port adapter keeps bringing up this error message:
I'm not sure what's going on here - is it not recognizing that it's plugged into USB port COM1, or what? The driver on the serial port adapter is up to date and I even changed its properties to COM1, for what that's worth. The MiniPov itself is working fine otherwise - turning on the battery pack causes the LEDs to light up in sequence as preprogrammed. Any feedback is appreciated.
(edited to add a more useful screencap)
minipov fail.png (40.68 KiB) Viewed 2543 times
Manicotti
Re: Programming - Can't find file/COM1
Postby Manicotti » Sat Nov 13, 2010 2:14 pm
I went through those threads, but I'm not sure how to apply that here. Where would I even check for the existence of the COM1 device, let alone access whatever might be using it already? The connections seem solid and so is the file path, so why can't it find the file?
Manicotti
Postby adafruit_support_bill » Sat Nov 13, 2010 3:41 pm
If you were able to change the properties on it, then it exists.
The most likely problem is that some application used it, then neglected to close the handle.
Close all applications and try again. If that fails, reboot and try again.
Postby Manicotti » Sat Nov 13, 2010 4:21 pm
arduwino wrote:If you were able to change the properties on it, then it exists.
Done and done, and apparently that's all it took. Thank you both for your help.
Manicotti
Return to MiniPOV
Users browsing this forum: No registered users and 2 guests
New Products [102]
LEDs[109]
Cables[60]
