Fading code for Light Box tutorial - lesson 3
For makers who have purchased an Adafruit Starter Pack, get help with the tutorials here!
Postby greenleaf » Sun Jul 03, 2011 2:56 pm
After completing lesson 3, I decided to write a new version that fades the LEDs gradually, giving a softer transition effect. Here's the code if anyone wants to play around with it. (Note that I'm using pins 9, 10, and 11 instead of 10,11, and 12, because pin 12 was giving me some problems). This code uses functions which are a little more advanced but you should be able to make sense of it:
  Light Box
  Rotates red, green, and blue LEDs through a cycle.  Looks pretty
  inside a light box or jar.
int redPin = 11;                  // Red LED connected to digital pin 12
int greenPin = 10;                // Green LED connected to digital pin 11
int bluePin = 9;                 // Blue LED connected to digital pin 10
int firstRun = 1;
void setup()                      // run once, when the sketch starts
  pinMode(redPin, OUTPUT);        // sets the digital pin as output
  pinMode(greenPin, OUTPUT);      // sets the digital pin as output
  pinMode(bluePin, OUTPUT);      // sets the digital pin as output
//  This function fades in the LED
void fadeIn(int led){
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
  analogWrite(led, fadeValue);
  delay(60);  // Change this to make the fade in slower or faster
//  This function fades out the LED
void fadeOut(int led){
  for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
  delay(60);  // Change this to make the fade out slower or faster
void loop(){                  // run over and over again
if (firstRun == 1) {          // if this is the first iteration, start with red
  fadeIn(redPin);
  delay(3000);
  firstRun = 0;
fadeIn(greenPin);
delay(3000); // RED + GREEN
fadeOut(redPin);
delay(3000); // GREEN
fadeIn(bluePin);
delay(3000); // GREEN + BLUE
fadeOut(greenPin);
delay(3000); // BLUE
fadeIn(redPin);
delay(3000); // RED+BLUE
fadeOut(bluePin);
delay(3000); // RED
greenleaf
Return to Arduino Starter Pack
Users browsing this forum: No registered users and 3 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
