Solar Charger Barrel Size?
Ideas and questions about MintyBoost kits
Postby iceboi714 » Thu Jan 05, 2012 6:54 pm
Hey,
I haven't read much about barrel plugs so I could be mistaken.
On the product page it says there is a 2.1mm to 1.4mm adapter which fits the barrel fine.
http://adafruit.com/products/390
But when reading about it off ladyada's site it mentions a 1.7mm plug.
http://ladyada.net/products/usbdcsolarlipo/use.html
Which one is it? or does both work fine?
Also with the Medium 2W Solar panel, the description says 3.5mm x 1.3mm, but off of Voltaic it says a 3.5mm x 1.1mm. Which is correct?
If someone can clear this up for me it would be great. Thanks.
iceboi714
Re: Solar Charger Barrel Size?
Postby adafruit » Fri Jan 06, 2012 10:17 am
the voltaic panels are 1.1mm
you can use 1.3-1.7mm (1.5mm nominal) with the jack
Postby iceboi714 » Fri Jan 06, 2012 5:39 pm
Great...thanks for the info :D
iceboi714
Return to MintyBoost
Users browsing this forum: No registered users and 2 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
