Chumby Hacker board noob question, serial problems
For Adafruit customers who seek help with microcontrollers
Postby redtank1971 » Thu Feb 09, 2012 11:00 pm
Just received my CHB from Adafruit. I'm trying to follow the Serial tutorial and have altered my FDTI according to the photo like this: black to ground, unused space, orange (TXD) to Rx, and yellow (RXD) to Tx. From there I hook the board up to my pc's usb port and attach a 5v power supply, but my pc does not see the CHB. I already have the FDTI drivers loaded because I have a Uno Ethernet board that I'm using for another project. Where am I going wrong? My pc's system is Windows Vista home premium 64. Last, is there another way to connect to the CHB besided usb/serial to get it set up?
Cris L.
redtank1971
Re: Chumby Hacker board noob question, serial problems
Postby redtank1971 » Fri Feb 10, 2012 8:53 am
I may have solved my own problem: after being unable to detect my CHB with one pc, I hooked it up to another pc in the house that is running XP, and it found my CHB, so I'm guessing it is a driver issue with the 1st pc running a different FTDI driver than the second. Is this the correct URL for the driver needed for this board?
http://www.ftdichip.com/Drivers/VCP.htm
Cris L.
redtank1971
Postby adafruit_support_bill » Fri Feb 10, 2012 9:04 am
The driver is actually for the FTDI cable itself. The link you posted is the correct one.
The UNO does not use an FTDI chip, so it requires a different driver.
Postby redtank1971 » Fri Feb 10, 2012 12:22 pm
Support,
Okay, thanks for the responce. I'm using the Arduino IDE serial monitor and am getting some strange characters when I login and do a "ls";
login
chumby-:/ # root
-/bin/sh: root: not found
chumby-:/ # ls
LICENSES etc linuxrc opt sbin usr
bin home lock proc share var
bitmap lib lost+found psp sys www
dev libexec mnt root tmp
chumby-:/ #
Is this a result of the IDE, or some other malfunction?
Cris L.
redtank1971
Postby adafruit_support_bill » Fri Feb 10, 2012 12:29 pm
I'm not a Chumby expert, but those look like terminal escape sequences to me. You probably want to try a terminal emulator program instead of the IDE serial monitor.
Postby redtank1971 » Sat Feb 11, 2012 6:29 pm
Support,
Yes, started using Putty for a terminal and no longer having issues with Windows. On the other hand, trying to access the sd card when in Linux is another story. Im running Ubuntu 11.04 and when I plug in the FTDI cable, it does not reccognize the device. While in terminal window I did a lsmod to see what packages are loaded, and found ftdi_sio and usbserial. Is there another package and/or driver required?
Cris L.
redtank1971
Postby adafruit_support_bill » Sun Feb 12, 2012 6:26 am
You might want to try plugging it into a different port. Also, check that your FTDI VCP driver is up-to-date: [url]http://www.ftdichip.com/Drivers/VCP.htm[/url
Return to Microcontrollers
Users browsing this forum: No registered users and 3 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
