Soldering temperature & tip cleaning
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
Postby skaxxo » Fri Feb 24, 2012 8:12 am
Hi
Which temperature do you use for a general soldering?
How do you clean your solder tips?
I use ~330°C on Lafayette SDD-9 and I clean the tips only with wet soft sponge
Arduino, MODs e DIY: blackstufflabs.com
skaxxo
Re: Soldering temperature & tip cleaning
Postby kkinderen » Fri Feb 24, 2012 9:27 am
330 - 350 on the Xytronic 379 and a brass "scrubby". Rarely use a wet sponge. Not sure why.
kkinderen
Postby adafruit_support_bill » Fri Feb 24, 2012 2:28 pm
On the bench, usually about 370 C (700 F) with a brass cleaning 'sponge'. In the field I use a damp rag or paper towel for cleaning.
Postby skaxxo » Fri Feb 24, 2012 3:19 pm
adafruit_support wrote:On the bench, usually about 370 C (700 F)
:shock:
lead-free?
skaxxo
Postby adafruit_support_bill » Fri Feb 24, 2012 3:33 pm
For lead-free work, I usually boost the tip temperature up to 725-750F. (385-400C).
Postby skaxxo » Fri Feb 24, 2012 3:38 pm
adafruit_support wrote:For lead-free work, I usually boost the tip temperature up to 725-750F. (385-400C).
It isn't too hot?
skaxxo
Postby adafruit_support_bill » Fri Feb 24, 2012 4:08 pm
The tip needs to be substantially hotter than the melting point of the solder in order to heat the whole joint to melting temperature quickly. If it takes too long to make the joint, the components themselves can overheat to the point of damage.
Postby Agent_24 » Tue Feb 28, 2012 4:47 pm
I run mine at about 350-370°C for most work, and bump it up to around 400°C if I need to.
I don't use lead-free solder.
Cleaning I do with a damp sponge. Never tried one of those brass cleaners, might give one a go sometime.
Agent_24
Return to Tools Tools Tools
Users browsing this forum: No registered users and 1 guest
New Products [113]
Raspberry Pi[81]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
