Ok is anyone working on the wave bubble or at least their version of it? I have been working on my version now for a month or 2 and have some questions maybe others have dealt with. First the basic idea is very straight forward as well there are schematics for different versions of these all over the web. I am using the front end circuit that make use of a quad op amp to integrate a square wave then buffer and mix with a noise signal from the reverse bias zener/386 amp configuration. Although this circuit works it does not work as well as I think it should, mostly in the noise generation portion. For the back end I am using a z-comm VCO and then to a standard rf transistor amp to one really cool smt antenna. When I look at my output on a spectrum analyzer I see a spike at 860 MHz but as far as scanning up from 800 to 890MHz I don’t get a good out. Also I am taking this output directly off the VCO. When I bias my rf transistor as shown in the test configuration by the manufacture the bias resistor gets HOT. But back to the VCO. I thought my front end circuit was less than perfect so I just connected a function generator to the tuning input of the VCO. Again I see a spike at 860MHz but nothing more. any ideas??
I have tried both triangle wave form at 8 V p-p as well as 8V p-p on a 4 volt dc bias as the tuning voltage for my VCO is 1-8 Vdc.
I thought someone here might have already figured out this or had a similar issue.
Thanks HC
