Motor Shield LED
Motor Shield LED
Postby bobcat18 » Sat Apr 14, 2012 6:38 pm
The green led on the Motor shield doesn't light when I apply power to the motor shield. I checked each connection before I soldered it and all the connections are correct.
I am getting power to the motor shield. I checked it with a multimeter. Can anyone help me with this.
Ron
bobcat18
Re: Motor Shield LED
Postby adafruit_support_bill » Sun Apr 15, 2012 4:57 am
Are you using external power or power from the Arduino? Make sure you have the jumper set correctly:
If you are still having problems, post clear photos of the front & back of the board and we'll take a look.
Postby bobcat18 » Mon Apr 16, 2012 9:41 am
I am using power from the arduino and a D cell 4 battery pack. However after checking the solder joints closely for the LCD I resoldered them and the green LCD is working fine now.
Thanks for your quick response.
bobcat18
Return to Arduino Shields from Adafruit
Users browsing this forum: No registered users and 5 guests
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
