I'm having some trouble. My specs:
kit: MiniPOV3 kit from Adafruit
OS: Mac OS 10.6.8
port: usb adapter that was included in kit
hello world: leds blinked in sequence when I first switched the board on
I installed AvrMacPack or what shows up in /usr/local/ as CrossPack-AVR via the option-1/suggested-method for mac. I'm not sure whether the discrepancy in names there is indicative of my problems or not. I copied the contents of the avrdude-macosx patch to /usr/local/CrossPack-AVR/bin/
When I plug the board into my usb port I get this message:
I don't know what to do with that.
Here's my check for the usb device adapter:
I'm not sure if the fact that the name of the adapter does not match the one in the tutorial (/dev/cu.PL2303-1B1) makes a difference.
Here I run avrdude. The terminal hangs...
...and the led furthest from the serial cable blinks in a pattern, 6 short and 1 longer:
o-o-o-o-o-o-ooo-o-o-o-o-o-o-ooo-o-o-o-o-o-o-ooo
This continues until I stop avrdude with ^C. I'm not sure where to go from here.
Sorry if this is a repeat question but I haven't found the answer in the forums. I'm not sure I know what to look for.
Thanks for your help.
