HAPPY LABOR DAY - ADAFRUIT IS OPEN - ALL ORDERS PLACED AFTER 11AM ET 9/4/2015 WILL NOT SHIP UNTIL TUESDAY 9/8/2015 - READ MORE!
Adaloader with Atmega 32U4 / Leonardo
by shibbs on Tue Nov 06, 2012 1:45 pm
I'm trying to get the adaloader set up the an atmega32U4, and I'm having trouble getting the adaloader coded adapted to the chip. I am trying to use the caterina leonardo hex code, as it comes compiled with arduino 1.0.1, and I wrote a little script to add the quotation marks to each line so that it could be placed into the images.cpp file. I'm trying to load it onto an atmega2560 with Aduino 1.0.1
The first issue that I ran into was that the pagesize (256) is too large for the uint8 originally allocated for that variable, so I converted all the uint8's to 16's, as well as update pagesize in the appropriate locations. I also believe i got all of the fuses set properly, and I can set that section with no issue.I am able to boatload a 328P with the original code, and I'm confident in my hardware as I'm able to get through the fuses just fine.
The issue that I'm running into at this point is that in the verification stage, it is failing on every single verification byte, suggesting that I haven't successfully programmed any of the bytes. In verbose debugging can see that it is trying to set the proper bytes, so my best guess is that either I'm not properly unlocking that section, or something in the verification stage is busted. For the unlock byte I'm using 0x30, which is consistent with the leonardo unlock byte in boards.txt.
I imagine the folks over here at adafruit have a standalone ISP rig they use for their atmega32U4 boards, any chance you guys could release that version of the code? Otherwise has anyone else gotten the adaloader working with a 32u4? I imagine that at this point I'm either way off (as in the code just won't port for the 32u4) or I have some small, fairly silly mistake. Attached is my modified version of code.cpp and my fuse bytes set in images.cpp
Shibbs
image_t PROGMEM image_32U4 = {
    {"caterina_leonardo.hex"},
    {"atmega32U4"},
    0x9587,            /* Signature bytes for 32U4 */
    {0x3F, 0xFF, 0xD8, 0xcb},            // pre program fuses (prot/lock, low, high, ext)
    {0x2F, 0x0, 0x0, 0x0},            // post program fuses
    {0x3F, 0xFF, 0xFF, 0xcb},           // fuse mask
    32768,     // size of chip flash in bytes
    256,   // size in bytes of flash page
#include "optiLoader.h"
#define VERBOSE     (1==1)
 * Bootload images.
 * These are the intel Hex files produced by the optiboot makefile,
 * with a small amount of automatic editing to turn them into C strings,
 * and a header attched to identify them
extern image_t *images[];
extern uint16_t NUMIMAGES;
 * readSignature
 * read the bottom two signature bytes (if possible) and return them
 * Note that the highest signature byte is the same over all AVRs so we skip it
uint16_t readSignature (void)
  SPI.setClockDivider(CLOCKSPEED_FUSES);
  uint16_t target_type = 0;
  Serial.print("\nReading signature:");
  target_type = spi_transaction(0x30, 0x00, 0x01, 0x00);
  target_type <<= 8;
  target_type |= spi_transaction(0x30, 0x00, 0x02, 0x00);
  Serial.println(target_type, HEX);
  if (target_type == 0 || target_type == 0xFFFF) {
    if (target_type == 0) {
      Serial.println("  (no target attached?)");
  return target_type;
 * findImage
 * given 'signature' loaded with the relevant part of the device signature,
 * search the hex images that we have programmed in flash, looking for one
 * that matches.
image_t *findImage (uint16_t signature)
  image_t *ip;
  Serial.println("Searching for image...");
  for (byte i=0; i < NUMIMAGES; i++) {
    ip = images[i];
    if (ip && (pgm_read_word(&ip->image_chipsig) == signature)) {
   Serial.print("  Found \"");
   flashprint(&ip->image_name[0]);
   Serial.print("\" for ");
   flashprint(&ip->image_chipname[0]);
   Serial.println();
   return ip;
  Serial.println(" Not Found");
  return 0;
 * programmingFuses
 * Program the fuse/lock bits
boolean programFuses (const byte *fuses)
  byte f;
  Serial.print("\nSetting fuses");
  f = pgm_read_byte(&fuses[FUSE_PROT]);
  if (f) {
    Serial.print("\n  Set Lock Fuse to: ");
    Serial.print(f, HEX);
    Serial.print(" -> ");
    Serial.print(spi_transaction(0xAC, 0xE0, 0x00, f), HEX);
  f = pgm_read_byte(&fuses[FUSE_LOW]);
  if (f) {
    Serial.print("  Set Low Fuse to: ");
    Serial.print(spi_transaction(0xAC, 0xA0, 0x00, f), HEX);
  f = pgm_read_byte(&fuses[FUSE_HIGH]);
  if (f) {
    Serial.print("  Set High Fuse to: ");
    Serial.print(spi_transaction(0xAC, 0xA8, 0x00, f), HEX);
  f = pgm_read_byte(&fuses[FUSE_EXT]);
  if (f) {
    Serial.print("  Set Ext Fuse to: ");
    Serial.print(spi_transaction(0xAC, 0xA4, 0x00, f), HEX);
  Serial.println();
  return true;         /* */
 * verifyFuses
 * Verifies a fuse set
boolean verifyFuses (const byte *fuses, const byte *fusemask)
  byte f;
  Serial.println("Verifying fuses...");
  if (f) {
    uint16_t readfuse = spi_transaction(0x58, 0x00, 0x00, 0x00);  // lock fuse
    readfuse &= pgm_read_byte(&fusemask[FUSE_PROT]);
    Serial.print("\tLock Fuse: "); Serial.print(f, HEX);  Serial.print(" is "); Serial.print(readfuse, HEX);
    if (readfuse != f)
      return false;
  if (f) {
    uint16_t readfuse = spi_transaction(0x50, 0x00, 0x00, 0x00);  // low fuse
    Serial.print("\tLow Fuse: 0x");  Serial.print(f, HEX); Serial.print(" is 0x"); Serial.print(readfuse, HEX);
    readfuse &= pgm_read_byte(&fusemask[FUSE_LOW]);
    if (readfuse != f)
      return false;
  if (f) {
    uint16_t readfuse = spi_transaction(0x58, 0x08, 0x00, 0x00);  // high fuse
    readfuse &= pgm_read_byte(&fusemask[FUSE_HIGH]);
    Serial.print("\tHigh Fuse: 0x");  Serial.print(f, HEX); Serial.print(" is 0x");  Serial.print(readfuse, HEX);
    if (readfuse != f)
      return false;
  if (f) {
    uint16_t readfuse = spi_transaction(0x50, 0x08, 0x00, 0x00);  // ext fuse
    readfuse &= pgm_read_byte(&fusemask[FUSE_EXT]);
    Serial.print("\tExt Fuse: 0x"); Serial.print(f, HEX); Serial.print(" is 0x"); Serial.print(readfuse, HEX);
    if (readfuse != f)
      return false;
  Serial.println();
  return true;         /* */
 * readImagePage
 * Read a page of intel hex image from a string in pgm memory.
// Returns number of bytes decoded
byte * readImagePage (byte *hextext, uint16_t pageaddr, uint16_t pagesize, byte *page)
  boolean firstline = true;
  uint16_t len;
  uint16_t page_idx = 0;
  byte *beginning = hextext;
  byte b, cksum = 0;
  //Serial.print("page size = "); Serial.println(pagesize, DEC);
  // 'empty' the page by filling it with 0xFF's
  for (uint16_t i=0; i<pagesize; i++)
    page[i] = 0xFF;
  while (1) {
    uint16_t lineaddr;
      // read one line!
    if (pgm_read_byte(hextext++) != ':') {
      error("No colon?");
      break;
    //  Serial.println("A");
    // Read the byte count into 'len'
    len = hexton(pgm_read_byte(hextext++));
    len = (len<<4) + hexton(pgm_read_byte(hextext++));
     // Serial.print("Len: "); Serial.println(len);
      cksum = len;
    //  Serial.println("B");
    // read high address byte
    b = hexton(pgm_read_byte(hextext++));
    b = (b<<4) + hexton(pgm_read_byte(hextext++));
    cksum += b;
    lineaddr = b;
   //   Serial.println("C");
    // read low address byte
    cksum += b;
    lineaddr = (lineaddr << 8) + b;
   // Serial.println("D");
    if (lineaddr >= (pageaddr + pagesize)) {
      Serial.println("Returning the beginning");
      Serial.print("\nLine address =  0x"); Serial.println(lineaddr, HEX);
      Serial.print("Page address =  0x"); Serial.println(pageaddr, HEX);
      return beginning;
   // Serial.println("E");
    b = hexton(pgm_read_byte(hextext++)); // record type
    cksum += b;
  //  Serial.print("Record type "); Serial.println(b, HEX);
    if (b == 0x1) {
     // end record!
     break;
#if VERBOSE
#endif
    for (byte i=0; i < len; i++) {
      // read 'n' bytes
      cksum += b;
#if VERBOSE
      Serial.print(b, HEX);
      Serial.write(' ');
#endif
      page[page_idx] = b;
      page_idx++;
      if (page_idx > pagesize) {
          error("Too much code");
     break;
    b = hexton(pgm_read_byte(hextext++));  // chxsum
    cksum += b;
    if (cksum != 0) {
      error("Bad checksum: ");
      Serial.print(cksum, HEX);
    if (pgm_read_byte(hextext++) != '\n') {
      error("No end of line");
      break;
#if VERBOSE
    Serial.println();
    Serial.println(page_idx, DEC);
#endif
    if (page_idx == pagesize)
      break;
#if VERBOSE
  Serial.print("\n  Total bytes read: ");
#endif
  return hextext;
// Send one byte to the page buffer on the chip
void flashWord (uint16_t hilo, uint16_t addr, uint16_t data) {
#if VERBOSE
  Serial.print(data, HEX);  Serial.print(':');
  Serial.print(spi_transaction(0x40+8*hilo,  addr>>8 & 0xFF, addr & 0xFF, data), HEX);
  Serial.print(" ");
#else
  spi_transaction(0x40+8*hilo, addr>>8 & 0xFF, addr & 0xFF, data);
#endif
// Basically, write the pagebuff (with pagesize bytes in it) into page $pageaddr
boolean flashPage (byte *pagebuff, uint16_t pageaddr, uint16_t pagesize) {
  SPI.setClockDivider(CLOCKSPEED_FLASH);
  Serial.print("Flashing page "); Serial.println(pageaddr, HEX);
  for (uint16_t i=0; i < pagesize/2; i++) {
#if VERBOSE
    Serial.print(pagebuff[2*i], HEX); Serial.print(' ');
    Serial.print(pagebuff[2*i+1], HEX); Serial.print(' ');
    if ( i % 16 == 15) Serial.println();
#endif
    flashWord(LOW, i, pagebuff[2*i]);
    flashWord(HIGH, i, pagebuff[2*i+1]);
  // page addr is in bytes, byt we need to convert to words (/2)
  pageaddr = (pageaddr/2) & 0xFFC0;
  uint16_t commitreply = spi_transaction(0x4C, (pageaddr >> 8) & 0xFF, pageaddr & 0xFF, 0);
  Serial.print("  Commit Page: 0x");  Serial.print(pageaddr, HEX);
  Serial.print(" -> 0x"); Serial.println(commitreply, HEX);
  if (commitreply != pageaddr)
    return false;
  busyWait();
  return true;
// verifyImage does a byte-by-byte verify of the flash hex against the chip
// Thankfully this does not have to be done by pages!
// returns true if the image is the same as the hextext, returns false on any error
boolean verifyImage (byte *hextext)  {
  uint16_t address = 0;
  uint16_t len;
  byte b, cksum = 0;
  while (1) {
    uint16_t lineaddr;
      // read one line!
      error("No colon");
      return false;
    cksum = len;
    cksum += b;
    lineaddr = b;
    cksum += b;
    cksum += b;
    //Serial.print("Record type "); Serial.println(b, HEX);
    if (b == 0x1) {
     // end record!
     break;
      // read 'n' bytes
      cksum += b;
#if VERBOSE
      Serial.print("$");
      Serial.print(lineaddr, HEX);
      Serial.print(":0x");
      Serial.write(" ? ");
#endif
      // verify this byte!
      if (lineaddr % 2) {
        // for 'high' bytes:
        if (b != (spi_transaction(0x28, lineaddr >> 9, lineaddr / 2, 0) & 0xFF)) {
          Serial.print("verification error at address 0x"); Serial.print(lineaddr, HEX);
          Serial.print(" Should be 0x"); Serial.print(b, HEX); Serial.print(" not 0x");
          Serial.println((spi_transaction(0x28, lineaddr >> 9, lineaddr / 2, 0) & 0xFF), HEX);
          return false;
      } else {
        // for 'low bytes'
        if (b != (spi_transaction(0x20, lineaddr >> 9, lineaddr / 2, 0) & 0xFF)) {
          Serial.println((spi_transaction(0x20, lineaddr >> 9, lineaddr / 2, 0) & 0xFF), HEX);
          return false;
      lineaddr++;
    cksum += b;
    if (cksum != 0) {
      return false;
      return false;
  return true;
// Send the erase command, then busy wait until the chip is erased
void eraseChip(void) {
  spi_transaction(0xAC, 0x80, 0, 0);   // chip erase
  busyWait();
// Simply polls the chip until it is not busy any more - for erasing and programming
void busyWait(void)  {
  byte busybit;
  do {
    busybit = spi_transaction(0xF0, 0x0, 0x0, 0x0);
    //Serial.print(busybit, HEX);
  } while (busybit & 0x01);
 * Functions specific to ISP programming of an AVR
uint16_t spi_transaction (uint16_t a, uint16_t b, uint16_t c, uint16_t d) {
  uint16_t n, m;
  SPI.transfer(a);
  n = SPI.transfer(b);
  //if (n != a) error = -1;
  m = SPI.transfer(c);
  return 0xFFFFFF & ((n<<16)+(m<<8) + SPI.transfer(d));
shibbs
