Sow how are they making one go 300ft plus?
Get help and show off your TV-B-Gone kit!
Postby nutt318 » Wed Jan 30, 2008 10:32 am
I was looking at the original tv-b-gone website and noticed that they are accepting pre-orders for the SHP model. Only 40 bucks for all US and Eroupe codes and its in a PDA case
https://www.tvbgone.com/cfe_tvbg_buy.tv ... f160a0bff5
So how are they getting the 300ft plus and how can we make one?
Anyone know?
nutt318
Postby oPossum » Wed Jan 30, 2008 11:41 am
Schematic: Page 1 Page 2
oPossum
Postby nutt318 » Wed Jan 30, 2008 12:11 pm
oPossum, Wow, thanks for the schematics. I wish I knew how to read these better. Is there a parts list for this one like the older version?
nutt318
Postby TheDon125 » Wed Jan 30, 2008 12:52 pm
Is it just me, or are the high power LEDs used in the newer tv-b-gone the same as those used in the tv-b-gone kit here? Any ideas how 3x the range was achieved? Appears as though the resistors on the LEDs have been dropped from 47 ohms to 10 ohms.
TheDon125
Postby Probedude » Wed Jan 30, 2008 2:21 pm
More importantly you'll see that the base of the transistors driving the LED's is NOT driven directly by the microcontroller unlike the Adafruit version but instead by using another transistor.
I don't know what the drive capability of the Atmel controller is but likely ~ 25mA. Using the transistor in between it can drive the emitter transistors much much harder.
Probedude
Postby nutt318 » Wed Jan 30, 2008 5:27 pm
On the schematics of this new version what kind of microprocessor is it using, an Atmel?
nutt318
Postby mtbf0 » Wed Jan 30, 2008 11:12 pm
seems to be a zilog z8 variant designed for use in ir applications.
mtbf0
Postby Probedude » Wed Jan 30, 2008 11:31 pm
I just noticed too that they're driving the IR led's directly off a 9V battery.
Seems excessive considering there is no dropping resistor to the IR LED's.
Wonder if they measured the current flowing into the LED's.
Probedude
Postby TheDon125 » Thu Jan 31, 2008 1:59 am
I ran it through one of those online LED calculator things, and figuring a fresh 9V and a 0.2V drop across the transistor, there is about 900mA flowing through those LEDs.
TheDon125
Postby nutt318 » Thu Jan 31, 2008 9:11 am
TheDon125 wrote:I ran it through one of those online LED calculator things, and figuring a fresh 9V and a 0.2V drop across the transistor, there is about 900mA flowing through those LEDs.
Is that alot compared to the older version?
Also on a side thought, Could anyone put the schematic into lamings terms. I cannot read schematics at all but just a little and was wondering if someone could bu the actual part number or description for each item.
nutt318
Postby Probedude » Thu Jan 31, 2008 2:24 pm
Can you post the URL? That calculation doesn't look correct to me.
Here's a link to some calcs done with a similar drive setup (9V being used to switch an IR) with the exception that a darlington was used. Scroll down to the "pulse driving the LED" section.
Sorry! Looks like I forgot to include the link.
http://www.rentron.com/Fire-Stick-III.htm
Probedude
Postby nutt318 » Thu Jan 31, 2008 2:36 pm
Link?
nutt318
Postby salsaman » Thu Jan 31, 2008 3:17 pm
Thanks, 'possum!
salsaman
Postby adafruit » Thu Jan 31, 2008 4:25 pm
why do you say theres 0.2V across the transistor...? Also have you accounted for internal resistance in the 9V battery?
Postby TheDon125 » Fri Feb 01, 2008 2:49 am
When I said the 0.2V across the transistor, I meant the voltage drop caused by the transistor (which looking at the datasheet is more between 0.4V and 0.75V, depending on the current flowing through the transistor). And no, I forgot about the internal resistance of the 9V, so my number is probably very off (the transistor itself is only rated for 600mA max)
TheDon125
Next
Return to TV-B-Gone Kit
Users browsing this forum: mibignistinly and 0 guests
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
