one sided pcb
Get help and show off your TV-B-Gone kit!
Moderators: arduwino, adafruit
Postby Probedude » Fri Mar 21, 2008 11:08 pm
Nice job oPossum - nice thick traces from the battery to the IR leds and the emitters of the transistors. Traces feeding IR LED's not also feeding the MCU.
Is there enough voltage with 2AA's to do a emitter follower to boost the base drive to the transistors? If so that would be a nice boost to the IR output.
Edit: doesn't look like it. Need to go to 3AA's.
Hey, you could with a single lipo cell!
Probedude
Postby jasonx » Sat Mar 22, 2008 8:42 am
Nice work oPossom :D
Great idea to have the option of on or off board switch & led.
This is probably going to sound a bit stupid but what is meant by "Split supply capable " ?
Is an "emitter follower" like the ehp version where a transistor drives the other transistors ?
If we used surface mount components could we use three battery's ?
jasonx
Postby oPossum » Tue Mar 25, 2008 6:56 am
Split supply would be one battery for the LEDs and another for the microcontroller.
The emitter follower (AKA common collector amplifier) is the transistor between the microcontroller and all the other transistors.
oPossum
CHiP
Postby oPossum » Tue Mar 25, 2008 6:59 am
Compact Hi Power (CHiP)
0.52 x 2.03 inches (AA size) :)
Drill IR LED holes in the centerline of the battery case to facilitate easy installation and removal.
EAGLE files
oPossum
Postby jasonx » Tue Mar 25, 2008 7:34 am
WOW :shock:
Your eagle skills never fail to impress me oPossom :D
Edit : there is no capacitor (unless I missed it ) in this design is it unnecessary with 3 AA's ?
jasonx
Postby Probedude » Tue Mar 25, 2008 9:30 am
Nice job as usual!
Now everyone should get together, vote on which one they want a batch of boards made for and then someone get them made!
Having a board house make them the design could then be double sided.
So is there a particular layout/design that's a winner?
Probedude
Postby oPossum » Tue Mar 25, 2008 5:42 pm
jasonx wrote:There is no capacitor (unless I missed it ) in this design is it unnecessary with 3 AA's ?
There wasn't room for the 100 uF cap and I am not sure how much benefit there is to having it, so it was omitted.
Here is a board with the 100 uF cap. Some work with a Dremel will be required to make it fit. The cap is smaller than the one used by the EHP (5mm vs 11mm) - see included parts list.
0.52 x 2.09 inches
EAGLE files
oPossum
Postby jasonx » Tue Mar 25, 2008 6:21 pm
I will have a go at etching the first one at the weekend :D
jasonx
Postby oPossum » Fri Mar 28, 2008 5:38 am
Double sided
0.50 x 2.00 inches (1 sq. in.)
EAGLE files
oPossum
Postby magician13134 » Fri Mar 28, 2008 9:33 am
Someone (Ladyada I guess) should start a sticky with all the different PCB designs in it, and them pictures of the final if anyone's made it. That'd be pretty helpful to anyone looking to make their own
Latest Projects:
Software: Michigan's Edition Politcal Blog (Still needs massive amounts of work)
Hardware: MintyMP3 v3 (Got a nice LCD screen, trying desperately hard to motivate myself to start working again)
magician13134
Postby Probedude » Fri Mar 28, 2008 10:00 am
oPossum,
You've got two pads really close together where the electrolytic cap is between the IR leds. What's the other pad for?
Probedude
Postby caitsith2 » Fri Mar 28, 2008 2:38 pm
If you look in the schematic, he is covering for 2mm (79mil) lead spacing caps, as well as 2.54mm (100mil) lead spacing caps.
caitsith2
Postby Probedude » Fri Mar 28, 2008 2:57 pm
caitsith2 wrote:If you look in the schematic, he is covering for 2mm (79mil) lead spacing caps, as well as 2.54mm (100mil) lead spacing caps.
Thanks, didn't notice that. Some board houses will complain about 2 holes being too close together due to possible breakout and then bit breakage. At first glance these adjacent holes jumped out at me.
I just looked up ExpressPCB's specs and it's:
> A minimum of 0.021" space must remain between adjacent holes. For example, the center-to-center distance between two pads with 0.020" holes must be 0.041" or greater.
Probedude
Postby CJM » Fri Aug 15, 2008 11:11 am
I would like Opossums board etching,
because of the ISP problem, however, I would like to be the jumper resistors.
I have the whole thing with EAGLE tried, but due to lack of experience nothing.
Could you please according to the circuit times for me?
Maybe the Jasonx?
Thank you
PS:
I hope you understand that G00gl € - English
CJM
Previous
Return to TV-B-Gone Kit
Users browsing this forum: No registered users and 0 guests
