blingM
blingM
Postby mtbf0 » Thu Feb 14, 2008 2:36 am
i've started work on a six led clone of the BlinkM. i used the method described in atmel's avr appnote 136 to get 18 channels of 8 bit pwm at a frequency of round about 120Hz. at present it accepts commands over the serial port to select an led and set its color. for instance, "da" selects the first led, (led "A"), then n800080 sets the color to magenta. the argument is a hexadecimal sextet. tomorrow, i begin work on color fading. there's also a command "r", for report, that dumps some debug info because i was being phenominally stupid there for a while.
anyway, here's some code for anyone interested. it doesn't use much of the arduino api, because i needed low latency on my timer interrupt.
/*     BlingM - 24 bit control of 6 RGB leds.
       based on ATMEL AVR Appnote 136 and BlinkM by ThingM
       by bobby cossum for theEntropyWorks.com
#define BAUD 9600
#define PINS 18
volatile unsigned char iteration;
volatile unsigned char LEDBuffer[PINS];
volatile unsigned char foo1, foo2, foo3, foo4;
ISR (TIMER2_OVF_vect) {
static unsigned char portBuffD, portBuffC, portBuffB;
static unsigned char CompBuffer[PINS];
//  first do port i/o so there's no variable latency caused by conditionals below
  PORTD = (PORTD && 0x03) | portBuffD;    // step lightly over serial RX and TX
  PORTC = portBuffC;
  PORTB = portBuffB;
  if (iteration == 0) {
//  don't be tempted to use a loop here.  because we're in an isr we're looking for
//  the fastest possible execution amd this way the array references are resolved at
//  compile time.
    CompBuffer[0] = LEDBuffer[0];        // led A - R, G, then B
    CompBuffer[1] = LEDBuffer[1];
    CompBuffer[2] = LEDBuffer[2];
    CompBuffer[3] = LEDBuffer[3];        // led B
    CompBuffer[4] = LEDBuffer[4];
    CompBuffer[5] = LEDBuffer[5];
    CompBuffer[6] = LEDBuffer[6];        // led C
    CompBuffer[7] = LEDBuffer[7];
    CompBuffer[8] = LEDBuffer[8];
    CompBuffer[9] = LEDBuffer[9];        // led D
    CompBuffer[10] = LEDBuffer[10];
    CompBuffer[11] = LEDBuffer[11];
    CompBuffer[12] = LEDBuffer[12];      // led E
    CompBuffer[13] = LEDBuffer[13];
    CompBuffer[14] = LEDBuffer[14];
    CompBuffer[15] = LEDBuffer[15];      // led F
    CompBuffer[16] = LEDBuffer[16];
    CompBuffer[17] = LEDBuffer[17];
// set alls pins high at start of pwm period
    portBuffD = 0xfc;
    portBuffB = 0x3f;
    portBuffC = 0x3f;
// as on time for each pin expires, set pin low
  if (CompBuffer[0] == iteration) portBuffD &= ~(1 << PD2);
  if (CompBuffer[1] == iteration) portBuffD &= ~(1 << PD3);
  if (CompBuffer[2] == iteration) portBuffD &= ~(1 << PD4);
  if (CompBuffer[3] == iteration) portBuffD &= ~(1 << PD5);
  if (CompBuffer[4] == iteration) portBuffD &= ~(1 << PD6);
  if (CompBuffer[5] == iteration) portBuffD &= ~(1 << PD7);
  if (CompBuffer[6] == iteration) portBuffB &= ~(1 << PB0);
  if (CompBuffer[7] == iteration) portBuffB &= ~(1 << PB1);
  if (CompBuffer[8] == iteration) portBuffB &= ~(1 << PB2);
  if (CompBuffer[9] == iteration) portBuffB &= ~(1 << PB3);
  if (CompBuffer[10] == iteration) portBuffB &= ~(1 << PB4);
  if (CompBuffer[11] == iteration) portBuffB &= ~(1 << PB5);
  if (CompBuffer[12] == iteration) portBuffC &= ~(1 << PC0);
  if (CompBuffer[13] == iteration) portBuffC &= ~(1 << PC1);
  if (CompBuffer[14] == iteration) portBuffC &= ~(1 << PC2);
  if (CompBuffer[15] == iteration) portBuffC &= ~(1 << PC3);
  if (CompBuffer[16] == iteration) portBuffC &= ~(1 << PC4);
  if (CompBuffer[17] == iteration++) portBuffC &= ~(1 << PC5);
//  and increment counter
  foo1 = iteration;
  foo2 = portBuffD;
  foo3 = portBuffB;
  foo4 = portBuffC;
void setup (void) {
//  set data direction registers
  DDRD = 0xFE;                             // all output, except serial RX
  DDRC = 0x3F;                             // all output, except RESET
  DDRB = 0x3F;                             // all output, except XTAL1 & XTAL2
//  initialize data for led buffer
  iteration = 0;
  for (int i = 0; i < PINS; i+=1)
    LEDBuffer[i] = 80;                    // initialize all to 50% duty cycle
  TCCR0B = 0;                             // stop timer 0
  TCCR0A = 0;                             // get back hardware pwm pins
  TCCR1B = 0;                             // stop timer 1
  TCCR1A = 0;                             // get back hardware pwm pins
//  set up timer 2, normal mode, prescale = 1, overflow interrupt enabled
  TCCR2B = 0;                              // stop timer 2
  TCCR2A = (1 << WGM21) | (1  << WGM20);   // diasble output compare pins
  TCNT2 = 0;                               // reset counter
  TIMSK2 &= !((1 << OCIE2A) | (1 << OCIE2B)); // disable output compare match interrupts
  TIMSK2 |= (1 << TOIE2);                  // enable timer overflow interrupt
  OCR2A = 63;                              // timer freq = 16M / 8/ 64, ca 122Hz
  TCCR2B = (1 << CS21) | (1 << WGM22);     // start timer in fast pwm mode 7, with prescaler = 8
//  set up baud rate
  UBRR0H = ((F_CPU / 16 + BAUD / 2) / BAUD - 1) >> 8;
  UBRR0L = ((F_CPU / 16 + BAUD / 2) / BAUD - 1);
// enable rx and tx
  UCSR0B = (1 << RXEN0) | (1 << TXEN0);
//  8 bits, no parity, 1 stop bit
  UCSR0C = (1 << UCSZ01) | (1 << UCSZ00);
unsigned char XMITBuffer[64];         // circular transmit buffer length is a power of
                                      // to avoid using modulus operator
unsigned char XMITHead, XMITTail;     // xmit buffer head and tail pointers
void USARTTransmit( unsigned char data ) {
//  wait for empty transmit buffer
  while ( !( UCSR0A & (1<<UDRE0)) );
//  Send it
  UDR0 = data;
unsigned char USARTReceive( void ) {
//  wait for data to be received
  while ( !(UCSR0A & (1<<RXC0)) );
//  return received data
  return UDR0;
//  output a byte in hex format to USART
void USARTHex (unsigned char ch) {
  unsigned char temp;
  temp = ch >> 4;
  temp += (temp > 9) ? 'a' - 10 : '0';
  USARTTransmit (temp);
  temp = ch & 0x0f;
  USARTTransmit (' ');
unsigned char ch;                      // input character
unsigned char args[4];                 // input arguments
unsigned char argnum;                  // input argument counter
unsigned char diode;                   // currently selected led
enum {START,                           // enumerated input states
      SELECT_DIODE,
      SET_RGB1,
      SET_RGB2,
      SET_RGB3,
      SET_RGB4,
      SET_RGB5,
      SET_RGB6,
      ERROR=255};
unsigned char state;                   // input state
void loop (void) {
  USARTTransmit (ch = USARTReceive ());// wait for character from USART
  switch (state) {
  case START :
    if (ch == 'd') {                   // select diode, single character argument a-f
      state = SELECT_DIODE;
      break;
    if (ch == 'r') {                   // report current state
      USARTTransmit ('\n');
      USARTHex (diode);
      USARTTransmit ('-');
      USARTHex (LEDBuffer [diode]);
      USARTHex (LEDBuffer [diode + 1]);
      USARTHex (LEDBuffer [diode + 2]);
      USARTHex (foo1);                 // iteration, from isr
      USARTHex (foo2);                 // PORTD
      USARTHex (foo3);                 // PORTB
      USARTHex (foo4);                 // PORTC
      break;
    if (ch == 'n') {                   // set rgb, get three undelimited hex values
      state = SET_RGB1;
      break;
    state = ERROR;
    break;
  case SELECT_DIODE :                  // selects current led a-f
    if ((ch >= 'a') && (ch <= 'f')) {  // sanity check
      diode = (ch - 'a') * 3;          // set pointer to red position in le bBuffer
      state = START;
    else state = ERROR;
    break;
  case SET_RGB1 :                      // get high nibble of argument byte
    argnum = 0;                        // set argument pointer
  case SET_RGB3 :
  case SET_RGB5 :
    if ((ch >= '0') && (ch <= '9')) ch -= '0';  // sanity check
    else if ((ch >= 'a') && (ch <= 'f')) ch -= 'a' - 10;
    else {
      state = ERROR;
      break;
    args[argnum] = ch << 4;            // multiply by 16 and save
    state += 1;                        // proceed to next state
    break;
  case SET_RGB2 :                      // get low nibble of argument
  case SET_RGB4 :
  case SET_RGB6 :
    else {
      state = ERROR;
      break;
    args[argnum++] += ch;              // add to saved high nibble & increment ptr
    if (state == SET_RGB6) {           // got enough values ...
      LEDBuffer[diode] = args[0];      // ... so save to led led buffers
      LEDBuffer[diode + 1] = args[1];
      LEDBuffer[diode + 2] = args[2];
      state = START;
    else state += 1;                   // or proceed to next state
    break;
  if (state == ERROR) {                // oops, give error indication
    USARTTransmit ('*');
    state = START;
//  ad nauseum ...
mtbf0
Postby mtbf0 » Thu Feb 14, 2008 10:50 pm
hey, i got a question...
i'm using pretty low value resistors to limit the current to my leds and they seem to reach their maximum brightness at about a 50% duty cycle, so i've essentially only got seven bits of resolution.
what i was wondering was if i used higher resistor values would i get finer control of the led brightness. right now i'm using 100 Ohms.
took a nap today instead of working on fading and scripting like i was supposed to.
bad mailman.
mtbf0
Postby Entropy » Fri Feb 15, 2008 8:33 am
mtbf0 wrote:hey, i got a question...
bad mailman.
If I recall correctly, human vision (esp. perception of brightness) is logarithmic, just like our hearing.
So the difference between 50% and 100% brightness is not nearly as great as you would think it would be.
Entropy
Postby mtbf0 » Sun Feb 17, 2008 1:47 pm
argh.
led fading. conceptually simple. practically annoying.
at its simplest.
set pwm duty cycle
wait
increase or decrease duty cycle
repeat 'til done
however on the ThingM BlinkM, which i hope to emulate, you have a variable starting and ending brightness and variable duration.
the default duration appears, from the datasheet, to be 5 seconds with the duty cycle updated at 30Hz. so we can calculate the change in intensity at each step as
deltaIntesity = (startIntensity - endIntensity) / (duration * rate)
and this has to be a floating point operation. and my little arduino is an 8 bit processor. with only integer operations in hardware. and i may be trying to do as many as six fades contemporaneously all while my timer2 interrupt keeps firing 31250 times a second.
i'm thinking of using a 16 bit fixed point scheme. 8 bit integer. 8 bit fraction. it'll require one 16 bit integer divide and duration * rate 16 bit adds, the high order byte of which will give me my duty cycle at each step.
or i could just code up the brute force method and see how it looks.
mtbf0
Postby Entropy » Sun Feb 17, 2008 8:14 pm
There is FP emulation for the AVR. It's big (adds 3-4k flash usage to your code) and slow (??? how long it takes) but should be fine if it's used in code that only runs 30 times per second.
Entropy
Postby mtbf0 » Tue Feb 19, 2008 3:35 pm
Entropy wrote:[
so i guess i could increase the values of my current limiting resistors which would decrease the maximum, (somewhat painful to look at), brightness of my leds and increase the apparent sensitivity of my controls.
sounds like a plan.
mtbf0
Return to Other Arduino products from Adafruit
Users browsing this forum: hgeagle and 2 guests
New Products [103]
LEDs[109]
Cables[61]
