So, what is a perceptual chronometer? It's basically a device that flashes numbers very quickly on an LED matrix or a 7-segment display. The human brain isn't able to make out the numbers since the LEDs forming the number flash, then the LEDs invert (the ones that were on go off and vice-versa) too quickly to make out what they are. Then, during a life-threatening or adrenaline filled situation, if the brain is able to "slow down time", you can read the numbers. Here's the original study:
http://youtube.com/watch?v=RjlpamhrId8
It looked really cool, so I threw one together on breadboard:
http://www.youtube.com/watch?v=xqm1yBLHDWA
That one is lacking in the features that I now have, though. The newer ones can change the delay speed and generate a new number if the button is held for 2 seconds. The second model I built was my first shot at using perfboarf. It turned out well, but I had to use gobs of hot-glue to make sure it stayed:
(Looks like a 34?)
Then today I etched up a PCB for it, and it looks great (except for one tiny little trace I'll need to cut that didn't etch). The pins are attached to the ATtiny2313 in a different order, so once I get it soldered and have the pins re-assigned, I'll upload the schematics, board files and source code for those interested.
