'make' fails on OS X Leopard compiling default Hello World?
Moderator: adafruit
Postby meese » Fri Feb 13, 2009 10:57 am
I'm trying to follow the 'hello world' tutorial on this page, but it doesn't seem to be working. The only thing I changed in the Makefile was "CC = avr-gcc.exe" to "CC = avr-gcc". This is what I get when I try to run it:
make
avr-gcc -I.. -mmcu=atmega644 -mmcu=atmega644 -Wall -gdwarf-2 -std=gnu99 -DF_CPU=28636360UL -Os -DVIDEO_MODE=1 -fsigned-char -MD -MP -MT uzeboxSoundEngineCore.o -MF dep/uzeboxSoundEngineCore.o.d  -x assembler-with-cpp -Wa,-gdwarf2 -c  ../kernel/uzeboxSoundEngineCore.s
/usr/local/bin/../lib/gcc/avr/4.1.1/../../../../avr/include/stdint.h: Assembler messages:
/usr/local/bin/../lib/gcc/avr/4.1.1/../../../../avr/include/stdint.h:116: Error: unknown opcode `typedef'
../kernel/uzeboxSoundEngineCore.s:560: Error: bad expression
../kernel/uzeboxSoundEngineCore.s:560: Error: missing ')'
../kernel/uzeboxSoundEngineCore.s:560: Error: `,' required
../kernel/uzeboxSoundEngineCore.s:560: Error: constant value required
../kernel/uzeboxSoundEngineCore.s:598: Error: `,' required
../kernel/uzeboxSoundEngineCore.s:598: Error: constant value required
../kernel/uzeboxSoundEngineCore.s:598: Error: garbage at end of line
../kernel/uzeboxSoundEngineCore.s:658: Error: bad expression
../kernel/uzeboxSoundEngineCore.s:658: Error: missing ')'
../kernel/uzeboxSoundEngineCore.s:658: Error: constant value required
../kernel/uzeboxSoundEngineCore.s:658: Error: garbage at end of line
make: *** [uzeboxSoundEngineCore.o] Error 1
It's actually much longer but I removed some of the repeating parts.
http://www.ladyada.net/make/fuzebox/download.html
meese
Re: 'make' fails on OS X Leopard compiling default Hello World?
Postby smadin » Sat Feb 14, 2009 9:23 am
I initially had a similar problem. There's a page on the Uzebox wiki for Mac OS X specific stuff: http://uzebox.org/wiki/index.php?title=Mac_OS_X_Specific. For me, running
avr-gcc-select 4
fixed it.
Something there is that doesn't love a wall,
That wants it down
--Robert Frost, "Mending Wall"
smadin
Postby Nender » Tue Apr 07, 2009 11:51 am
That fixed it for me as well.
Nender
Postby keithkml » Thu Apr 30, 2009 11:52 am
For some reason my AVR pack didn't come with avr-gcc-select. I tried installing avr-gcc with darwinports and it doesn't seem to come with this command either. Not sure what to do to get past these opcode error messages...
keithkml
Postby keithkml » Fri May 01, 2009 8:51 am
Oops! Turned out I had OSX-AVR and CrossPack installed at once, and it was using the OSX-AVR version of everything! Now it works!
keithkml
Return to Fuzebox
Users browsing this forum: mibignistinly and 3 guests
New Products [102]
LEDs[109]
Cables[60]
