Info widget: server should be 72.14.176.143?
Talk about YBoxen, widgets, Propeller hacking, etc!
Postby gigamegawatts » Sun Mar 01, 2009 8:44 pm
After building my ybox2 this weekend, I was a little disappointed when the info widget displayed html source, not formatted text. :(
I double-checked the instructions in the "Use It" pages, puttered around with the configuration settings, poked around this forum, and came across a post that said the server address has moved from 208.131.149.67 to 72.14.176.143. Making that change fixed the problem.
Assuming that this is a permanent change, I thought I should post to a) politely suggest that the info in the Use It section be updated to show the new address, b) suggest the infowidget binary in the Downloads section be updated to use the new address by default, c) add an item to the forum to give the new address greater visibility.
Other than that, I'm really delighted with the kit. :D It was a pleasure to build, a marvel to behold -- the Propeller, TV out and ethernet in a tin! -- and I look forward to using it to learn about Propeller programming.
Dan.
gigamegawatts
Re: Info widget: server should be 72.14.176.143?
Postby adafruit » Fri Mar 13, 2009 11:09 am
thanks for the suggestions, i've updated them!
Postby adafruit » Wed Mar 25, 2009 11:36 am
ive copied infowidget to my server
you can now use
settings.setString(settings#SERVER_HOST,string("www.ladyada.net"))
settings.setData(settings#SERVER_IPv4_ADDR,string(207,58,139,246),4)
settings.setWord(settings#SERVER_IPv4_PORT,80)
settings.setString(settings#SERVER_PATH,string("/infowidget/?zipcode=95008"))
it shouldnt move, like, ever :)
thanks harrison!
Return to YBox2
Users browsing this forum: No registered users and 1 guest
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
