324 stepper motor color code
by chon7 on Fri May 25, 2012 12:25 am
Hi, I recently purchase Stepper motor - 200 steps/rev, 12V 350mA -
Can any one here provide me some help on color code. This motor have 4 wires, red, yellow, green, and brown.
chon7
Re: 324 stepper motor color code
by adafruit_support_bill on Fri May 25, 2012 6:02 am
It is listed in the product description:
To connect to our shield, put the wires in this order: Red, Yellow, skip ground, Green, Brown
by chon7 on Fri May 25, 2012 7:23 pm
Hi, I did not have shield board, I purchased your motor for difference board.
so you can provide me some help of color code.
Will it be some thing like red A, yellow /A, green B brown /B.
chon7
by adafruit_support_bill on Sat May 26, 2012 5:28 am
Yes. That's right.
by fortis208 on Mon May 08, 2017 1:28 am
I also have the same problem, I purchased Stepper Motor HAT and a stepper motor with wires (Black, Green, Red, Blue) in the specification, it says Black ---- Green, Red --- Blue. Now I don't know where to connect those wires on the board. Please, I need help. Thanks!
BTW, the stepper motor is Nema 17HS16-2004S1.
fortis208
by adafruit_support_bill on Mon May 08, 2017 6:19 am
That motor is not compatible with the HAT. It has a very low (1.1 ohm) phase resistance - indicating that it is intended for use with a current limiting 'chopper' driver.
https://learn.adafruit.com/all-about-st ... he-stepper
https://learn.adafruit.com/current-limi ... th-drv8871
by fortis208 on Tue May 09, 2017 1:45 am
We are new to using the stepper motor, since we have this Stepper Motor HAT and the motor, what can you suggest for us to do?
Thank you very much for the help..
fortis208
by adafruit_support_bill on Tue May 09, 2017 6:09 am
The options are to use a different motor, or use a different driver.
This motor works well with the HAT: https://www.adafruit.com/product/324
The DRV8871 is capable of driving the 17HS16-2004S1 motors you currently have. https://learn.adafruit.com/current-limi ... th-drv8871
by fortis208 on Wed May 10, 2017 3:33 pm
We will purchase this motor. Thank you very much!
fortis208
