I am now able to take a screenshot of Pi (only via LXT terminal) using scrot -- then put it on a usb-stick move to a PC.
Big question is can I upload the JPEG file to an Adafruit Forum post?
1. answer is I cannot place jpeg directly in body of post - no clue why.
2. try sennding as an attachment - here goes.
Test - Place Screenshot on Forum Post
- RussellJames
- ss9.jpg (80.34 KiB) Viewed 1233 times
- RussellJames
Re: Test - Place Screenshot on Forum Post
It appears I can send screenshots as an attachment - progress made.
Now can you share how to post jpeg in the body of a post? Doing so will allow me to respond to your request to send screenshots to help with a problem we are working on involving the Learn topic - make the Pi a WiFi access point (shot title).
I await the sharing of your know-how.
Cheers
Cheers
- Franklin97355
You should be able to click the Choose File button then click the ADD THE FILE box.
then click place inline where it will add it to the message. I just did this while testing the steps for you. You may have to move the location around to put the photo where you want it.- RussellJames
Test -- placing screenshot (jpeg) in body of Adafruit post -- here goes.
I think I got it! Thanks
Now one last trick to learn - I have not been able to figure out or find help with taking a screenshot when the Pi boots direct to the command line. Knowing how to do this without using a digital camera would be every helpful when troubleshooting start-up (boot loading problems) or using the command line to setup the Pi say, as a WiFi hotspot.
Can you help?
Can you help?
- tdicola
Getting a screenshot could be tricky, but I think you can get a lot of all the messages by running:
This will output all the kernel's log output, which should include those boot messages (near the top). You can actually run this command and direct it to a file so it's easier to view & attach to a forum post by running:
Then grab the text file pi_boot.txt and copy it to your computer.
dmesg
dmesg > pi_boot.txt
- RussellJames
Makes sense to me - I will give it a go.
Thanks for the help.
- RussellJames
Unfortunately, I must of missed something as each time I try to insert a .jpg from a digital camera I get this message;
The image file you tried to attach is invalid.
What is going on? I was able to do this yesterday as a test, but can't do it now.
Thank you for any advice you may provide.
- RussellJames
Test
It seems that a JPEG file must be sized to 640 x 480 before it will post - who Knew!
Perhaps, when time is available, someone can create a "Learn" for attaching and posting photos to the body of a forum post.
Cheers
Cheers
- Franklin97355
The file needs to be under 1 meg, 800x600 seems to work too.
