Specifications - Flow meter Plastic #828
by 1bobc on Wed Feb 03, 2016 6:07 pm
Do you have a flow meter compatible with this sensor?
Does this sensor require signal conditioning before the processor?
Durability: minimum 300,000 cycles – what is a cycle?
1bobc
Re: Specifications - Flow meter Plastic #828
by adafruit_support_bill on Wed Feb 03, 2016 6:22 pm
It is just the sensor. You would need a microcontroller to interface with it and measure the flow.
When powered by 5v, the outputs will be compatible with any 5v microcontroller.
The 'cycles' refers to revolutions of the flow-sensing wheel.
by 1bobc on Thu Feb 04, 2016 9:58 am
Thank you for you're quick response.
Does that mean at 2l/m the sensor would be rated for 20,000 liters?
1bobc
by adafruit_support_bill on Thu Feb 04, 2016 10:09 am
Yes. That is correct.
by robdavila on Thu Mar 03, 2016 10:19 pm
With reference to your product #828 would it be possible to have the same product made but with 3/4" size pipe and connections. It mentions in the specification that it is good for 300,000 cycles - how would that compare with a regular domestic mechanical meter? Currently we use approximately 20,000 liters per month, does that mean I would need to change the sensor every month?
robdavila
by franklin97355 on Thu Mar 03, 2016 11:02 pm
These are hobby parts and we do not make them. If you need something more sturdy I would recommend Google for a manufacturer that can get you parts more suited to your project.
franklin97355
by robdavila on Thu Mar 03, 2016 11:05 pm
thanks for the reply
robdavila
