feather M0 not showing under ports
by Boone_Docker on Tue Feb 23, 2016 10:43 am
My feather will not show up under ports. When I press the reset button it just flashes the yellow led 1 time and pc doesn't see it.
I also tried double clicking the reset and I get a steady flashing red but my computer still doesn't see it.
I just got this feather and was running blink when it suddenly stopped.
Any ideas?
thanks!
Boone_Docker
Re: feather M0 not showing under ports
by adafruit_support_mike on Thu Feb 25, 2016 4:27 am
Let's see if anything is amiss with the hardware. Post a photo showing the component side of the board please, well enough lit and focused that we can see any assembly errors. 800x600 images usually work best.
by Boone_Docker on Thu Feb 25, 2016 9:33 pm
I tried the rest again and my computer recognized the board on port 4. I tried to upload Blink again and it failed. I'm attaching a screen shot of the upload attempt and a picture of Feather.
2016-02-25 (3).png (147 KiB) Viewed 1426 times
Boone_Docker
by adafruit_support_mike on Thu Feb 25, 2016 11:52 pm
Just to confirm: did you reset with a double-press as described in this tutorial page?
https://learn.adafruit.com/adafruit-fea ... -proto/faq
by Boone_Docker on Fri Feb 26, 2016 12:59 am
Yes, when I first connect I get a quick yellowish blink, then nothing, then I double click the reset and get a steady blinking red.
Boone_Docker
by adafruit_support_mike on Fri Feb 26, 2016 11:14 pm
That's the correct behavior for the bootloader.
Check your USB cable. There's a plague of charge-only cables that have USB connectors at both ends but no wires for the D+ and D- signals. You can verify the cable by connecting another, known-working USB device with it.
