I just put together my MiniPOV and want to try out some images on it. I downloaded the image converter sketch and the latest version of Processing (3.0.1), and installed the CP5 library, but when I try to run the sketch I get an error of:
the method showOpenDialog(Component) in the type JFileChooser is not applicable for the arguments (MiniPov4_ImageConverter)
This points to Line 205:
if (fc.showOpenDialog(this) == JFileChooser.APPROVE_OPTION)
I have virtually zero Java experience so while I've done some searching around I can't find a mechanism to address this that I actually understand how to implement. Is this an incompatibility with Processing 3 (the tutorial references Processing 2.1 or something), or something more fundamental I've messed up? If the former, is it one that can be addressed in a straightforward manner? I would rather not have multiple versions of Processing installed, and I don't see the merit in learning to use an old version of the software over learning on what will presumably be the standard version for a while.
