Mini POV4
Re: Mini POV4
by adafruit2 on Mon Jan 08, 2018 8:30 pm
what iron are you using?
adafruit2
Site Admin
Re: Mini POV4
by adafruit_support_carter on Tue Jan 09, 2018 1:30 pm
I've added an image below with some markups to help guide you.
The red circles indicate potential solder bridges, which you should check and try to fix. In particular, the ones labeled A and B relate to powering the individual color channels of the RGB LEDs. If these have shorts, then you will have issues seeing other colors. Anecdotally - it appears that the red channel is the only one without any solder bridge issues, which may explain why you are only seeing red.
The yellow circles and labels indicate the individual LED pins. The pins labeled 1, 2, and 3 should be common across all the LEDs. That is, all the Pin 1's are tied together, all the Pin 2's are tied together, and all the Pin 3's are tied together. You can test this with a multimeter to make sure they are soldered OK.
Re: Mini POV4
by Mkhalil2 on Tue Jan 09, 2018 2:02 pm
So fix the solder bridges and should I just check the LEDs to make sure theyre working
Mkhalil2
Re: Mini POV4
by adafruit_support_carter on Tue Jan 09, 2018 2:17 pm
For now, just try and fix the solder bridges and see what effect it has on the LEDs.
Re: Mini POV4
by Mkhalil2 on Tue Jan 09, 2018 2:22 pm
Okay I’ll post the redone solder when I finish
Mkhalil2
Re: Mini POV4
by Mkhalil2 on Wed Jan 10, 2018 5:40 pm
Hi I did the resoldering and the result is the same
Mkhalil2
Re: Mini POV4
by mbkhali on Wed Jan 10, 2018 5:44 pm
mbkhali
Re: Mini POV4
by adafruit_support_carter on Wed Jan 10, 2018 6:42 pm
Bummer. Can you post a photo of the latest solder job as well.
Re: Mini POV4
by mbkhali on Wed Jan 10, 2018 8:40 pm
here is the updated solder
mbkhali
Re: Mini POV4
by adafruit_support_carter on Wed Jan 10, 2018 9:03 pm
Looks like the solder bridge(s) in circle B (from my photo above) might still be there. Do you have a multimeter that can do continuity testing?
Re: Mini POV4
by mbkhali on Wed Jan 10, 2018 9:12 pm
I do not have a multimeter, but the I got rid of the solder bridges in B I just couldn’t get a good angle to show it
mbkhali
Re: Mini POV4
by adafruit_support_carter on Thu Jan 11, 2018 12:51 pm
I think unfortunately it could still be a soldering issue. Sometimes the solder bridges can be very tiny and hard to see visually. That's where the multimeter would help. You could verify continuity, or lack of, to test for bridges. Additionally, it would be helpful to be able to measure voltages at various locations to provide additional information about what might be going wrong.
I can see at least one pad that looks to be poorly wetted out. See image below. There's a good illustration of common problems here:
https://learn.adafruit.com/adafruit-gui ... n-problems
Try reading through that guide and see if you can go over all of your connections and rework them to be as close as possible to what is shown as a good solder joint:
https://learn.adafruit.com/adafruit-gui ... lder-joint
Re: Mini POV4
by mbkhali on Thu Jan 11, 2018 1:40 pm
Okay I’ll go over all of them again
mbkhali
