Led cube
Led cube
by viper905 on Fri Mar 13, 2009 3:52 pm
Makezine did a great job with the 3x3x3 led cube, but is there a way to make it a 4x4x4 or a 5x5x5 cube using the minipov3 kit? 8)
viper905
Re: Led cube
by mtbf0 on Sun Mar 15, 2009 6:45 am
the cube uses one pin for each of nine leds on a level, then three more pins to select a level.
4x4x4 would require 16 pins + 4 pins, which would be a perfect fit for a 20 pin microcontroller if it you didn't need vcc, ground and reset.
then there's charlieplexing, a technique of which i have an imperfect understanding. you could wire a 4x4x4 cube with nine i/o lines or a 5x5x5 cube with twelve i/o lines, but the wiring would be really challenging.
mtbf0
Re: Led cube
by viper905 on Sun Mar 15, 2009 1:01 pm
Thanks for the insight. I might look into getting either another microconrtoller or look into charlieplexing.
viper905
Re: Led cube
by gwv2002 on Fri Mar 27, 2009 10:00 am
I'm working on the 3x3 cube and see the placement of 8 wires but not the 9th anode, cathode and resistor. I have figured out a cube with eight lights per level but I'm curious about the mysterious 9th. Can anyone enLighten me?
Thanks.
gw
gwv2002
Re: Led cube
by mtbf0 on Sat Mar 28, 2009 6:36 pm
you'll have to solder directly to the portd pads where the socket is soldered to the circuit board. you can take a look at the source code for the project to figure out which pins are used. there will be one for the ninth anode and one each for the common cathodes of each of the three levels of the cube.
mtbf0
Re: Led cube
by Pixelmonster on Thu May 13, 2010 9:49 am
I'd like to build a LED cube, but I didn't found a circuit board layout on the web.
I only found a picture of the circuit diagram, but I'd need the original file. (I think it's designed with eagle ?!)
If someone have the layout, I'd only need the original, because I'd manipulate it myself.
Please help me.
Thanks, Michael
PS: Sorry for bad english :oops:
Pixelmonster
Re: Led cube
by mtbf0 on Thu May 13, 2010 4:22 pm
Pixelmonster wrote:I'd like to build a LED cube, but I didn't found a circuit board layout on the web.
the particular led cube under discussion here is based on lady ada's minipov3 board. the project was originally present as a weekend project on the make magazine blog. it is described on mitch altman's site, here.
mtbf0
Re: Led cube
by Pixelmonster on Fri May 14, 2010 1:35 am
Thanks for your answer and sorry for my bad phrasing.
I know how to build the cube, but I need the circuit board layout of the MiniPov v3.
If I have this, I could add a resistor and switch the led sockets to simple pads for soldering, ...
Pixelmonster
Re: Led cube
by adafruit_support_bill on Fri May 14, 2010 5:14 am
The Eagle files are on the MiniPOV3 web page: http://www.ladyada.net/make/minipov3/download.html
Re: Led cube
by Pixelmonster on Fri May 14, 2010 12:03 pm
I knew this page, but I didn't saw this link.
Thank you very very much!
Fast and good help, I like this forum!
Thanks!!!
Pixelmonster
Re: Led cube
by Pixelmonster on Sat May 22, 2010 4:34 pm
it's me again (sorry :( )
Now I built my LED Cube with a manipulated circuit board and it's working quiet good.
But it has a big problem. It's flickering and I don't know why.
Do you know why?
Thanks, Michael
Pixelmonster
