pov success
MiniPOV4 and previous versions
jpersonna
pov success
Post by jpersonna »
Thanks for a great kit. It went together easy with the online instructions, and works: Win7, oldish Dell, actual Serial ... though I just noticed that I didn't actually solder one end of D3. Apparently this is optional.
Since I'm a total beginner I soldered the Elenco practice kit SP-3B first. That was nice, progressing from easy to hard with 100 or whatever solder points. A version of that with a more modern feel might be a good product for the "maker" constellation.
Oh, and for some reason I just like to watch LEDs count:
#include <avr/io.h>      // this contains all the IO port definitions
#include <util/delay.h>
int main(void) {
  // set port B to output only
  DDRB = 0xFF;
  // count up port b with 1/2 sec delay
  PORTB = 0;
  while (1) {
    _delay_ms((double)500);
	if (PORTB == 255)
		PORTB = 0;
	else
		PORTB++;
Dumb, I know, but strangely fascinating.
I assume that I could have just kept incrementing PORTB and let it wrap .. that carry would end up somewhere.
jpersonna
Re: pov success
Post by jpersonna »
Heh, I could change the delay to 5.6 minutes and call it a wrist-watch. B8(00000000) to B8(11111111) in 24 hours, with B8(10000000) as high noon.
mtbf0
Re: pov success
Post by mtbf0 »
no need for this bit...
   if (PORTB == 255)
      PORTB = 0;
   else
      PORTB++;
  PORTB++;
will suffice. 255 + 1 is zero.
jpersonna
Re: pov success
Post by jpersonna »
Thanks, that's what I was asking about at the end, the wrap and carry. I guess not knowing the architecture I wasn't sure the carry wouldn't be pushed somewhere else. I recall some processors with paired registers and such.
mtbf0
Re: pov success
Post by mtbf0 »
all of the i/o registers on the tiny2313 are 8 bits except for a couple involving timer1, which is a 16-bit timer.
only thing funner than blinking leds is fading leds. gives you a chance to play with timer1, too. stick drinking straws over the leds for diffusers.
jpersonna
Re: pov success
Post by jpersonna »
Cool, I'll try that.
Return to “MiniPOV”
