minipov programming problem
MiniPOV4 and previous versions
virtualeb
Post by virtualeb »
Hi I am having a problem programmining my minipov
I am using a usb to 232 converter.
After my first attempt at programming I tried setting the delay to 3000.
After that things got worse.
To me it looks like it almost worked?!
here is a listing of my results:
C:\minipovfirmware>make program-minipov
avrdude -p attiny2313 -P com4 -c dasa -U flash:w:minipov.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 1.17s
avrdude: Device signature = 0x008000
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: AVR device not responding
avrdude: reading input file "minipov.hex"
avrdude: input file minipov.hex auto detected as Intel Hex
avrdude: writing flash (310 bytes):
Writing | ################################################## | 100% 131.80s
avrdude: 310 bytes of flash written
avrdude: verifying flash memory against minipov.hex:
avrdude: load data flash data from input file minipov.hex:
avrdude: input file minipov.hex contains 310 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 126.00s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x12 != 0x00
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK
avrdude done. Thank you.
make: *** [program-minipov] Error 1
make: *** [program-minipov] Interrupt
this check.
this check.
virtualeb
Re: minipov programming problem
Post by virtualeb »
Never Mind. I replaced the batteries and it now works. :lol:
Return to “MiniPOV”
