๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Has anyone integrated an FTDI?
by hjmiii on Sat Feb 20, 2010 4:54 pm
I'm attempting to avoid the serial to USB cable requirement by building a FTDI based usb port onto the MinPOV3. For a prototype I had an Arduino MiniUSB adapter laying around, so based on the schematic I wired the 5 needed pins to the equivalent ports on the MiniUSB. My PC sees the ftdi correctly as COM5, and I've made all the adjustments (Downloaded the special AVRDude and config, changed the makefile accordingly for com5). But when I try to program it just says the AVR isn't responding. I tried adjusting the delay.
Am I using the wrong pins, or are any other needed? Based on the schematic I'm sending pin 3 to transmit, 4 to DTR, 5 to ground, 7 to RTS, and 8 to CTS.
hjmiii
Re: Has anyone integrated an FTDI?
by mtbf0 on Sat Feb 20, 2010 6:58 pm
y'ever go blind while reading a post and respond with gibberish?
i know i do.
mtbf0
by adafruit on Sun Feb 21, 2010 1:03 pm
you could use the rts/cts pins as well as tx
then you would have a button to press when you program it for 'reset'
by naxxtor on Tue Mar 09, 2010 9:07 pm
I designed one:
http://tinkersoc.org/wiki/projects:minipov
However it's entirely untested at the moment. I've hooked up the control lines similarly to you - be interesting to know what the outcome is - I may want to change my design a bit.
naxxtor
