๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday October 14, 2019 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday October 11 will go out Tuesday October 15 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Rotating display on minipov3
by athlon2005 on Fri Mar 26, 2010 1:24 pm
Hi
I recently built my own minipov3 kit from scratch for my college project. Now the thing is that I want to extend the functionality of minipov3 similar to that of spokepov. I was wondering if there is a way to display text on minipov as its rotating on a motor. I wanted the display to be visible clearly, so i guess i'll have to make some major changes in the program and may be the hardware also. Please help me out as there is not much time left to finalize my project
Sid
athlon2005
Re: Rotating display on minipov3
by mtbf0 on Sat Mar 27, 2010 7:38 am
this can be pretty simple or pretty hard. the minipov has a sensor input connected to pd2, (i think). just the thing for a hall effect sensor.
i knew a guy used a fan motor with a skate wheel attached to the shaft to spin a bicycle wheel with a minipov on it. he got lucky and the speed was just right so all he needed to do was modify the firmware so the display would start every time the sensor passed a magnet.
if you're not so lucky, you'll have to modify the firmware to calculate rpm and adjust the timer parameters to make the display readable.
mtbf0
by athlon2005 on Sat Mar 27, 2010 1:06 pm
Hi
Thanks mtbf0 for your input. I realised that I'll have to use the hall sensor, but I guess the role of hall sensor is only to find the rpm of the rotating display. so if i keep the rpm constant, i wouldn't need a hall sensor. The problem that I'm getting is to map the rectangular text (i.e. in minipov3) to circular text for rotating display. Because if I use the same code and rotate the display, the relative speeds of leds near centre and towards perimeter is different, so the text gets distorted and unreadable.
Please someone help me out with the coding as i'm not very well versed with it.
athlon2005
