Minipov+Mac+SB2Serial - ???
by AnnaOnWeb on Sun Jun 06, 2010 6:05 pm
I have a MiniPov-Kit, a Mac with avrdude, the right driver for the USB2Serial.
When I enter in Terminal:
avrdude -p t2313 -P /dev/tty.PL2303-002075FD -c dasa -U flash:w:largeimage.hex
the programming seems to work LED3 permanently lighting, #1 and #2 blinking...
And after a while I get this:
avrdude: AVR device not responding
this check.
avrdude done. Thank you.
Does anyone have an idea?
Thank you very much in advance,
Anna
AnnaOnWeb
Re: Minipov+Mac+SB2Serial - ???
by mtbf0 on Mon Jun 07, 2010 1:44 am
make sure you are powering the board when you try to program it.
check your soldering. look for cold joints on the db-25 connector. check the three diodes and r10-12.
did you build the board as a pov toy or something else? i have used a minipov board to drive an led cube and have to disconnect it from the outputs for led1 and led2 in order to be able to program it successfully.
mtbf0
Re: Minipov+Mac+SB2Serial - ??? solved
by AnnaOnWeb on Mon Jun 07, 2010 11:23 am
Thank you!
After digging further and further into this forum I found the most simple solution:
Even if connected to a powered hub: Connect the Serial Adapter to an USB port on your machine.
Thats it! And I found a cu.-file in my /dev-folder which looked more useful.
Oh man ... how long does programming take ....
AnnaOnWeb
Re: Minipov+Mac+SB2Serial - ??? solved and a result
by AnnaOnWeb on Mon Jun 07, 2010 6:23 pm
Foto am 07-06-2010 um 23.41.jpg (87.3 KiB) Viewed 1796 times
Success! My Kay was very impressed :-)
AnnaOnWeb
